Thread: Tow bar electrics 7 way bypass relay
  1. Tow bar electrics 7 way bypass relay
    May 2010
    portsmouth uk
    Hi there I am new to this web site and I thank you all in anticipation of a little help.
    My A4 2005 1.9 Tdi saloon B7 I believe is the full title. I have fitted the tow bar easy peasy that was but the electrics are a bit puzzling.
    I have followed the instructions as best I can however the lights on the trailor dont seem to function at all.
    Power is to the bypass relay as is the earth.
    The CANBUS signals from the cars lights are wired in but still I get nothing out of the relays.
    Has anyone done this before and if so any advice on testing installation would be helpful.
    Regards
    Dave
  2. Re: Tow bar electrics 7 way bypass relay
    do u get anything out of the relays if u just touch a flylead positive wire onto terminals 124567 of the relay? is the earth to the white wire good? check it with the multimeter on volts scale
  3. Re: Tow bar electrics 7 way bypass relay
    Coventry
    I,ve fitted 3 of these relays without issue. 2 of these feature in how to guides, one in vw and one in Audi.
  1. what happens if i dont activate tow bar electrics?
    By allroadkev in forum VCDS - General Questions
    Last Post: 08-05-2010, 11:05 AM
  2. Tow bar electrics
    By m12oby in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-02-2010, 01:30 PM
  3. Question Mk3 golf tow bar electrics general question
    By robert1z in forum Golf MK3 - 1993 - 1999
    Last Post: 27-10-2009, 07:31 PM
  4. sharan tow bar electrics
    By deano224 in forum Touran - Sharan - Caravelle
    Last Post: 13-08-2009, 01:01 AM
  5. Question Tow Bar electrics, is it worth buying a specific wiring kit?
    By RobsA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-05-2008, 10:06 AM
