Thread: Central locking problem
  1. Central locking problem
    I am suffering a recurrence of a central locking/alarm problem which I cured a couple of years ago by replacing corroded bits of the wiring loom.
    My nearside rear door has been working on and off for about a month, and now both rear doors are permanently locked.
    My problem is that even with the battery disconnected, (and unlike the last time this happened) the inner door handles will not open the doors. They lift the buttons, but these spring back when the handle is released.
    Does anyone know how I can open the doors.
    My car is 11 years old and has done 170000m, so I would be quite happy if I could disable the central locking and continue to lock up manually.
    Yours in anticipation
    Desparate
  2. Re: Central locking problem
    Norfolk
    Have you got electric rear windows or manual. Check the ccm wires like last time. That's the most likely problem.
  3. Re: Central locking problem
    Aug 2007
    I had a problem like this with the front passenger door of my 2003 Passat estate. After removal of the door panel from inside I eventualy had to smash the locks to bits to open the door only to find that the lock was probably fine but that one cable in the wiring loom had snapped.
    I decided the better fix would have been to identify the broken cables by continuity testting each coloured cable, with the connector blocks disconnected, then bypassing the broken cable/s to activate the lock, open the door and then run the bypass cable through the rubber sleeve in the door hinge. Would have saved me the price of the new lock!
  1. Audi 80 Central Locking Problem
    By tp5harp in forum 80 - 90
    Last Post: 20-05-2010, 09:30 PM
  2. Please Help Central Locking Problem
    By ghowe79 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-03-2010, 10:40 AM
  3. Please Help Central Locking Problem
    By MBEN in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-03-2010, 08:48 PM
  4. A4 Central locking
    By gre22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-01-2008, 03:08 PM
  5. Bizarre Central Locking problem
    By swiss_steve in forum Beetle 2000-
    Last Post: 14-03-2007, 09:21 PM
