Thread: A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
  1. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    Apr 2010
    Helmond NL
    My A6 has now a constant drain on the battery I think.
    This is the fault log I have pulled with my cable.
    The drain seems to be approx 760 mAh. MMi Latest revision.
    Does anyone have a moment of genius to point me to the right place to what you see in the log?
    Many thanks for looking Luusje
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
    56 61 62 67 69 72 76 77
    VIN: WAUZZZ4F26N053xxx Mileage: 138250km/85904miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    62-Door,Rear Left -- Status: OK 0000
    67-Voice Control -- Status: OK 0000
    69-Trailer -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F2 910 401 R HW: 4F0 907 401 B
    Component: 2.7L V6TDI G000AG 0010
    Revision: --H01--- Serial number:
    Coding: 0011372
    Shop #: WSC 66565 257 00032
    2 Faults Found
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.05
    Time: 15:24:57
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.63 V
    Bin. Bits: 00101100
    Torque: 89.7 Nm
    005481 - Cruise Control Switch (E45): Implausible Signal
    P1569 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 126 /min
    Torque: 323.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 6.61 V
    Bin. Bits: 00001100
    Torque: 269.1 Nm
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F1 910 156 R HW: 09L 927 156 A
    Component: AG6 09L 2.7 TDI 132 0030
    Revision: --H01--- Serial number: 4060368
    Coding: 0000002
    Shop #: WSC 02327 785 00200
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
    Component: ESP 8.0 quattro H04 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004488
    1 Fault Found
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 153
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.05
    Time: 15:27:03
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0282
    Hex Value: 0x0024
    Hex Value: 0x018A
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10600600221150
    Coding: 0000131
    Shop #: WSC 00217 211 85596
    Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H44 0070
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0054
    2 Faults Found
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 153
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.05
    Time: 15:14:53
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 153
    Mileage: 0 km
    Time Indication: 0
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350GO057582334
    Coding: 0001001
    Shop #: WSC 02335 785 00200
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H07 0050
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F1 820 043 S
    Component: KLIMABETAETIGUNGH12 0160
    Revision: 00000027 Serial number: 00000000164549
    Coding: 0000278
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 HW: 4F0 907 279
    Component: ILM Fahrer H15 0080
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0003121
    Part No: 4F1 910 113 D
    Component: Wischer AudiC6 H10 0040
    Coding: 00022800
    Shop #: WSC 02335
    Part No: 4E0 910 557
    Component: REGENLICHTSENSORH10 0050
    Coding: 00141886
    Shop #: WSC 02335
    2 Faults Found
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 153
    Mileage: 138220 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 153
    Mileage: 138220 km
    Time Indication: 0
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBE7203853
    Shop #: WSC 00000 000 00000
    1 Fault Found
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 153
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.05
    Time: 15:14:28
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 42 AIRBAG AUDI8RH29 0260
    Revision: 07H29000 Serial number: 0037LD091F6W
    Coding: 0013362
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H07 0230
    Revision: 00H07000 Serial number: 90025051880191
    Coding: 0002042
    Shop #: WSC 02323 785 00200
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0080
    2 Faults Found
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 153
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 A HW: 4F0 920 931 B
    Component: KOMBIINSTR. M73 H16 0630
    Revision: 00000000 Serial number: 4PT351F75
    Coding: 2113043
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H10 0060
    Revision: 10 Serial number: 1200805707811B
    Coding: EDFE73C41B7104
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
    Component: MNS ECE H45 1060
    Revision: 00000000 Serial number: 305GU057617719
    1 Fault Found
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 153
    Freeze Frame:
    Hex Value: 0x4BB9
    Hex Value: 0xE236
    Hex Value: 0x0044
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 F HW: 4F0 959 793 F
    Component: TSG FA H21 0050
    Coding: 0001546
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H19 0140
    Revision: 01400019 Serial number: 01005608620000
    Coding: 0393861
    1 Fault Found
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 153
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.05
    Time: 15:19:54
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H09 0350
    Revision: 20S00001 Serial number: 03006050120069
    Coding: 0000102
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000114370
    Coding: 0001013
    2 Faults Found
    Freeze Frame:
    Fault Status: 00110010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 153
    Mileage: 138220 km
    Time Indication: 0
    Date: 2010.04.05
    Time: 15:14:00
    Freeze Frame:
    Voltage: 5.900 V
    Temperature: 19.0°C
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 153
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 6.000 V
    Temperature: 19.0°C
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 792 F HW: 4F0 959 792 F
    Component: TSG BF H21 0050
    Coding: 0001546
    Address 53: Parking Brake Labels: 4F0-910-801.lbl
    Part No SW: 4F0 910 801 HW: 4F0 907 801
    Component: EPB C63C0030 H03 0030
    Revision: C63C0030
    Coding: 0000521
    Shop #: WSC 02334 785 00200
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
    Component: AFS 1 H01 0030
    Revision: 00000001 Serial number:
    Coding: 0000016
    Part No: 4F0 941 329 B
    Component: AFS-Modul links H02 0020
    Component: AFS-Modul rechtsH02 0020
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 394G 057572566
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: ENERGIEMANAGER H12 0490
    Revision: 00000000 Serial number: 00000000075883
    Shop #: WSC 22195 142 02786
    Part No: 4F0 915 105 D
    Component: von VA0 1507150001
    Coding: 344630393135313035442056413031353037313530303031
    Shop #: WSC 00000 384 00290
    5 Faults Found
    02256 - Quiescent Current
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 153
    Mileage: 138199 km
    Time Indication: 0
    Date: 2010.04.01
    Time: 21:46:45
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.03
    Time: 14:15:48
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.03
    Time: 14:15:56
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.03
    Time: 14:16:06
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.03
    Time: 14:16:16
    Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 F HW: 4F0 959 795 F
    Component: TSG HL H21 0050
    Coding: 0001026
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
    Component: SDS 3502 UK H46 0630
    Revision: 00000000 Serial number: 00000801070039
    Shop #: WSC 12336 024 394758
    Address 69: Trailer Labels: 4F0-910-383.lbl
    Part No SW: 4F0 910 383 HW: 4F0 907 383
    Component: ANHAENGERELEKTR H02 0020
    Coding: 0000331
    1 Fault Found
    02777 - Handwheel Contact Switch (F354)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 153
    Mileage: 138220 km
    Time Indication: 0
    Date: 2010.04.05
    Time: 15:23:00
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 F HW: 4F0 959 794 F
    Component: TSG HR H21 0050
    Coding: 0001026
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 C HW: 4F0 919 283 C
    Component: Parkhilfe 8-Kan H12 0020
    Revision: 00H12000 Serial number: 11820519202026
    Coding: 0211016
    Shop #: WSC 131071 1023 2097151
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H10 1130
    Revision: 00000000 Serial number: 00000007566818
    Coding: 0010900
    Thursday,01,January,2009,14:28:53:26365
    VCDS Version: Beta 812.4
    Data version: 20090214
    Control Module Part Number: 4F0 910 181 E
    Component and/or Version: ENERGIEMANAGER H12 0490
    Software Coding:
    Work Shop Code: WSC 22195
    Additional Info: 4F0915105D von VA0 1507150001
    Additional Info: Geraet 02786
    5 Faults Found
    Freeze Frame
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 156
    Mileage: 138378 km
    Time Indication: 0
    Date: 2010.04.09
    Time: 10:48:16
    Freeze Frame
    Fault Priority: 7
    Fault Frequency: 4
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.03
    Time: 14:15:48
    Freeze Frame
    Fault Priority: 7
    Fault Frequency: 3
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.03
    Time: 14:15:56
    Freeze Frame
    Fault Priority: 7
    Fault Frequency: 3
    Mileage: 138223 km
    Time Indication: 0
    Date: 2010.04.03
    Time: 14:16:06
    Freeze Frame
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 138523 km
    Time Indication: 0
    Date: 2010.04.13
    Time: 10:34:58
    Audi A6 4F, 2.7Tdi 225Hp S-Line Avant 2005
  2. Re: A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    Ambler, PA, USA
    If you charge the battery, then you clear the faults, does the battery management fault return?
    Seems to me the battery management has failed and as result is causing all of the other faults along with the battery not remaining charged. But all this is a guess.
  3. Re: A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    I had the same faultr on my 2005 A6 (C6) 3.0 tdi quattro, had to get the MMI software updated to latest (there is a fault with the radio/stereo where it draws power even when car is off) and also got my battery manager updated to the latest version cus there is a fault in that as well. Never had the fault again (2 year now - and same battery).
    Your battery manager is at v 0490 - which is latest.
    MMI needs to be at version 5570.
  1. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  2. What to buy A6 2.0TDI or A6 2.7TDI or A4 2.0TDI
    By sanstorm999 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-08-2007, 01:07 PM
  3. Draining Battery A6 Avant 1.9TDI
    By oldsurfdude in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-01-2007, 10:55 PM
  4. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
  5. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
