Thread: how to reset engine warning light
  1. how to reset engine warning light
    Oct 2006
    is there a simple way of resetting the engine warning light or do i need a machine?
  2. extinguish engine warning light
    scotland
    39 Post(s)
    Dis-connect the battery earth terminal for half an hour and that should be it,if it comes on again the problem is not resolved.You will need to do a throttle body adaption afterwards if it's a b5 you will need vag-com , on a b5.5 only requires switching on the ignition for three minutes before starting.Your car will then run on the stock ECU parameters and will feel different at first but once you drive it will re- learn all the settings it had lost and return to normal.
    Calum
  1. A4 Engine Management Warning Light
    By ukdeluded in forum Audi A4 - Archive Topics
    Last Post: 04-12-2007, 08:18 PM
  2. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
  3. Engine Warning Light 2001 Passat
    By derekdublin in forum Passat - Archive Topics
    Last Post: 09-02-2007, 08:10 PM
  4. Engine management System Warning light
    By petergregg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-01-2007, 03:46 AM
  5. Engine warning light 01 GTI 150bhp
    By fixedgear in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-10-2006, 08:58 PM
