Thread: A4 2.5 TDI wont Start - Fuel Injector Pump?
Results 1 to 8 of 8
  1. A4 2.5 TDI wont Start - Fuel Injector Pump?
    Mar 2008
    2
    My Audi A4 2.5 tdi 1998 MY broke down last week (was low on fuel)
    The RAC had the engine run on easy start (so cam belt OK)
    Topped up diesel
    And there was fuel coming out of the injectors, but it would not start on Diesel only?
    The Garage said the Fuel Injector Pump is showing as a fault but they dont have the full Audi diagnostics?
    They mention and ECU being part of the pump and that it wil be an expensive job.
    Any advise on what to do next?
  2. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Nov 2008
    Cramlington,Northumberland
    3
    Its an Electronic Pump yes, but the ECU is seperate.A fault code read is your best bet before chucking money at it.
    Alan.
    A6 Avant Le Mans
  3. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Mar 2008
    2
    Thanks Alan,
    I have been told its the EDC part of the pump.
    Found www.dieselpumprepairs.com who claim to be able to repair the EDC? has anyone used there services?
    Does anyone know of the cheapest option of getting a second hand pump?
    Scrap yard?
    Part No 059130106DX??
  4. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Nov 2008
    3
    Hi,how sure is the garage of the pump being at fault? Other issues can put a Pump Fault on,but because its the effect of a fault,not the cause of it.
    Alan.
    A6 Avant Le Mans
  5. Thanks OTW thanked for this post
  6. The Following User Says Thank You to Alan02 For This Useful Post:
    OTW (04-03-2010)
  7. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Jul 2008
    Wales
    0
    Mine went last year, 2.5tdi AFB. the AA get it running with spray, but otherwise wont run. I read the codes and it showd (01318 control module for injection pump (J399) 37-00 faulty) which means that the circket boart that is bilt into the pump had gone. this place did mine http://www.pbasher.com/ you can ether send yours in, they fix it and send it back, about 4 days, or they can send out a recon pump next day but costs a bit more. But you should read the codes first to be poitive
    Good luck
    Lyn.
  8. Thanks OTW thanked for this post
  9. The Following User Says Thank You to audia4lyn For This Useful Post:
    OTW (04-03-2010)
  10. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Mar 2008
    2
    Hi Lyn,
    How did you get the pump removed from the vehicle?
    I'm hereing its a hard job?
  11. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Jul 2008
    Wales
    0
    Yes it is, I had to pull the front end out into service position, take the viscus fan off, take off front plastics, lock the cams and crank with a locking kit, remove the belt from the pump to the right hand cam, take off the injector pipes and fuel lines, undo the four bolts that hold the pump, and I think that was it. and if you do all that, you might as well change the breather filter that sits in the v whilst you have good access. it sounds a lot but it is possible. when as the timing belt done?
  12. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Mar 2010
    stroud uk
    2
    Unplug and remove the injection pump ecu module. Open up the module and check the circuit board for dry/cracked solder joint. These pump ecus usually have a few high current, larger through-hole components which switch a SOLENOID or SPILL VALVE in the pump. This is why it won't start - the fuel supply is cut off. Thermal cycling/vibration takes its toll especially on larger, heavier components on these modules. If you are very lucky you might find that two minutes with a soldering iron reflowing dodgy looking joints will get the thing working.
    You have nothing to lose by checking inside the ecu. Seal back with silicone sealant if necessary
  1. 2.5 TDI V6 Fails to Start
    By snapdragon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-10-2013, 08:31 PM
  2. Please Help A4 2.5 TDI Convertible
    By JonLees in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-02-2010, 01:44 PM
  3. 1999 V6 2.5 TDI A4 SE - Will not start HELP!
    By triman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-01-2007, 01:31 PM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
VW Audi Forum is an AUTHORISED retailer for the Surf City Garage range of car care products
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
