Thread: dpf fault
  1. dpf fault
    Aug 2008
    i have a 2.0tdi 170, it has some faults, the dpf symbol and flashing glow plugs light are on the dash. i did a scan and found a faulty pressure sensor, this has now been changed. it also looks like a regeneration of the dpf is needed, this has been tried but with no joy. i have now swapped another dpf from a car with no faults just to check that it is not the dpf itself that is at fault. again it shows dpf symbol. i have listed the latest scan below. if anyone can point me in the right direction of what to try next it would be a great help. thanks in advance to anyone who can help.
    Monday,01,March,2010,18:14:39:24293
    VCDS Version: Release 908.1
    Data version: 20091018
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
    VIN: WAUZZZ8P67A026705 Mileage: 76400km/47472miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
    Component: R4 2.0l PPD1.2 1247
    Revision: --H22--- Serial number: AUX7Z0F5FNT0LE
    Coding: 0000078
    Shop #: WSC 00613 210 85940
    1 Fault Found:
    008194 - Particulate Trap Bank 1: Efficiency Below Threshold
    P2002 - 006 - Short to Plus
    Freeze Frame:
    Fault Status: 11010001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 76409 km
    Time Indication: 0
    Date: 2010.03.01
    Time: 07:41:13
    Freeze Frame:
    RPM: 832 /min
    Torque: 64.0 Nm
    Speed: 0.0 km/h
    (no units): 63.0
    Pressure: 0.0 mbar
    Lambda: 19.8 %
    Time: 5091.8 s
    Readiness: N/A
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 043 E HW: 02E 927 770 AE
    Component: GSG DSG 070 1153
    Revision: 04507000 Serial number: 00000606071413
    Coding: 0000020
    Shop #: WSC 06314 000 00000
    No fault code found.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
    Component: KlimavollautomatH18 0300
    Revision: 350776 Serial number: 8P0820043M
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000005927266
    Coding: 01884F07A214100000000000000000000008FE175C0100
    Shop #: WSC 06314 000 08192
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H12 3720
    Revision: 91H12372 Serial number: 0037W002ET12
    Coding: 0071612
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H34 0070
    Coding: 0011112
    Part No: XXXXXXXXXXX
    Component: E0221 H03 0080
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
    Component: KOMBIINSTR. VDO H18 0560
    Revision: D0H18002 Serial number: 2245F002002163
    Coding: 0000403
    Shop #: WSC 50741 143 61874
    1 Fault Found:
    00003 - Control Module
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 20149 km
    Time Indication: 0
    Date: 2008.08.12
    Time: 11:57:44
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 30001066158803
    Coding: 3F0F0B4207000101
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D0H18002 Serial number: AUX7Z0F5FNT0LE
    Shop #: WSC 00000 000 00000
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000560
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.079 H07 1806
    Shop #: WSC 02069 000 90108
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 198000186D288505489AC63300
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH27 0160
    Revision: 00005 Serial number: 30659630422228
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 H
    Coding: 0000560
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H52 0100
    Revision: 02S Serial number: AUZ2Z3F4150797
    Coding: 0001003
    Shop #: WSC 06435 000 00000
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
  2. Re: dpf fault
    Aug 2008
    i have now managed to do a regen down to 11%, the fault code has gone but it still has the dpf sign on the dash.
  3. Re: dpf fault
    Mar 2007
    sure somewhre you have to do an adaption to remove the light
  4. Re: dpf fault
    Aug 2008
    all sorted now, just left the car stood for a while after the regen, when i came back started it up and all faults now gone.
  1. Help needed from experinced A6 owners
    By robmorphet in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-03-2010, 08:27 AM
  2. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
  3. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  4. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  5. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
