Thread: Rear washer jet, Avant 80 tdi
  1. Rear washer jet, Avant 80 tdi
    Jan 2010
    Ipswich UK
    With the help of info on the forum, I have had great fun getting everything working again on my 1993 Avant tdi. Leaks and electrics have all been sorted - thanks to everyone's posts. A great resource in the absence of a workshop manual. To return some of the favours and provide info for others - my problems were 1. leaks caused by crack in bulkhead behind the nearside drain hole in the plenum chamber and also by the bonnet cable working a hole 2. most of the wiring exposed or even broken halfway between the exit from the roof and entry into the tailgate (need to remove the rubber to find it) 3. dodgy wiper relays.
    One issue remains - the rear window washer jet. The pump works - it squirts out water when the pipe is disconnected from the jet, so I need to clean out the jet. Does anyone know how to remove the jet from the wiper mechanism so I can do this? Any suggestions how to do this or clean the jet in situ gratefully received. Everything will be working then! (except the illumination for the clock in the instrument panel!).
  2. Re: Rear washer jet, Avant 80 tdi
    Jan 2009
    towcester northants
    try blowing down the jet with a electric tyre pump
  1. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  2. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  3. Rear washer jet?
    By AWH in forum Chat - Completely Off Topic
    Last Post: 01-11-2008, 02:40 PM
  4. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  5. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
