Thread: Epc light code 16524
  1. Epc light code 16524
    Dec 2007
    2001 A3 1.6 daughters car
    code 16524 EPC light on
    cleared came stright back on
    i know its the lamba but can it cause the car to run crap cut out etc ?
  2. Re: Epc light code 16524
    1836 Post(s)
    An AVU engine then. Yes it could cause it to act up but the failure of the sensor is more likely to be a symptom of an upstream problem than the fault itself. If the fault comes straight back, all you can do is fit a new sensor and go from there.
  3. Re: Epc light code 16524
    Dec 2007
    what other problems could lead to the lamba failing ?
    no other codes never missed a beat untill last few days when light come on and would you know how many wires the lamba has
  4. Re: Epc light code 16524
    1836 Post(s)
    PM me the cars reg number. Do not even think about bodging in a universal sensor, they are crap!
  5. Re: Epc light code 16524
    Dec 2007
    PM sent
  6. Re: Epc light code 16524
    1836 Post(s)
    16524 (P0140) -035- Bank 1, probe 2. No activity.
    Being as it is the after cat sensor it is not so much of an issue. The genuine part number is 06A 906 262 AJ. It is a four wire sensor, two whites to the heater, a grey and a black. Bosch offer a direct fit part (0 258 006 257) or a universal part (0 258 986 602) and it is available from various other companies.
  7. Re: Epc light code 16524
    Dec 2007
    ty + rep on its way
  1. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  2. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  3. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  4. ABS Light - Code 00597
    By DJJoker in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-07-2009, 10:21 AM
  5. EPC Problems
    By lfu2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-05-2008, 08:44 PM
