Thread: Esp malfunction/parking brake
  1. Esp malfunction/parking brake
    Oct 2009
    Scotland
    1
    Hi all i am still having problems with the above errors, i thought it was because of a flat battery as when i run the jump leads from my other car i don't get the errors and the car starts fine but i've bought a new Bosch battery and its still happening. Could it be the altenator?
    I've also had a scan done and here are the results, i noticed there are quite a few errors recorded (any advice very welcome & thanks!)-
    Tuesday,19,January,2010,17:57:20:26365
    VCDS Version: Release 805.0
    Data version: 20080529
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
    62 72
    VIN: WAUZZZ*********** Mileage: 122160km/75906miles
    01-Engine -- Status: Malfunction 1010
    02-Auto Trans -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    62-Door,Rear Left -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 401 A HW: 4F0 907 401 A
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H01--- Serial number:
    Coding: 0011372
    Shop #: WSC 00409 210 70349
    1 Fault Found:
    005658 - Glowplug for Cylinder 1 (Q10): Open Circuit
    P161A - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 122152 km
    Time Indication: 0
    Date: 2010.01.18
    Time: 08:31:30
    Freeze Frame:
    RPM: 0 /min
    Torque: 269.1 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.86 V
    Duty Cycle: 15.0 %
    Temperature: 7.2°C
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F0 910 156 H HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0080
    Revision: --H01--- Serial number: 0033875
    Coding: 0000001
    Shop #: WSC 02331 785 00200
    2 Faults Found:
    18258 - Powertrain Data Bus: Missing Message from ECU
    P1850 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 122159 km
    Time Indication: 0
    Date: 2010.01.19
    Time: 14:50:09
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 25.0
    Temperature: 5.0°C
    T.B. Angle: 60.0°
    18289 - Powertrain Data Bus: Missing Message: Acceleration Request
    P1881 - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 122159 km
    Time Indication: 0
    Date: 2010.01.19
    Time: 14:50:09
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
    Component: ESP8 quattro H03 0010
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004488
    2 Faults Found:
    01314 - Engine Control Module
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 33
    Mileage: 122159 km
    Time Indication: 0
    Date: 2010.01.19
    Time: 14:50:12
    Freeze Frame:
    Hex Value: 0x0200
    Hex Value: 0x00A2
    Hex Value: 0x0000
    Hex Value: 0x0095
    Hex Value: 0x00FF
    02083 - Message for Delay Request
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 33
    Mileage: 122159 km
    Time Indication: 0
    Date: 2010.01.19
    Time: 14:50:12
    Freeze Frame:
    Hex Value: 0x0200
    Hex Value: 0x00A2
    Hex Value: 0x0000
    Hex Value: 0x0095
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H30 0220
    Revision: 31050601 Serial number: 10600300035652
    Coding: 0000019
    Shop #: WSC 00409 210 88600
    Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H43 0070
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H35 0020
    No fault code found.
    Address 07: Control Head Labels: Redir Fail!
    Part No SW: 4F0 910 729 P HW: 4F0 035 729 F
    Component: MMI Cockpit H90 0120
    Revision: C41300FE Serial number: AUZ6Z3D6RG0683
    Coding: 0100002
    Part No: 4F0 910 609 B
    Component: Bedienteil MMIC6H03 0010
    1 Fault Found:
    01320 - Control Module for Climatronic (J255)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 34
    Mileage: 122164 km
    Time Indication: 0
    Date: 2010.01.19
    Time: 15:12:55
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 B
    Component: KLIMABETAETIGUNGH11 0100
    Revision: 00000022 Serial number: 00000000031683
    Coding: 0001046
    1 Fault Found:
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 34
    Mileage: 122159 km
    Time Indication: 0
    Date: 2010.01.19
    Time: 14:50:14
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H18 0250
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0000101
    Shop #: WSC 00409 210 62383
    Part No: 4F2 910 113
    Component: Wischer AudiC6 H04 0150
    Coding: 00062736
    Shop #: WSC 00409
    Part No: 4E0 910 557
    Component: REGENLICHTSENSORH10 0040
    Coding: 00141886
    Shop #: WSC 00409
    Address 0E: Media Player 1 Labels: Redir Fail!
    Coding: 0100002
    Address 15: Airbags Labels: 4F0-910-655.lbl
    Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
    Component: 38 AIRBAG AUDI8RH28 0250
    Revision: 04H28000 Serial number: 0037LD031SE4
    Coding: 0013112
    Shop #: WSC 00409 210 61188
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H07 0230
    Revision: 00H07000 Serial number: 90026041760095
    Coding: 0102141
    Shop #: WSC 02323 785 00200
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H04 0080
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 950 L
    Component: KOMBIINSTR. M73 H08 0460
    Revision: 00000000 Serial number: 4I130XH64
    Coding: 0001443
    Shop #: WSC 00409 210 91061
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 33
    Mileage: 122159 km
    Time Indication: 0
    Date: 2010.01.19
    Time: 14:50:11
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
    Component: Gateway H09 0030
    Revision: 09 Serial number: 08008046160070
    Coding: 6CFE53C41B0104
    Shop #: WSC 02325 785 00200
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 33
    Mileage: 122159 km
    Time Indication: 0
    Date: 2010.01.19
    Time: 14:50:10
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 C HW: 4F0 959 793 C
    Component: TSG FA H10 0020
    Revision: 00000000 Serial number: €
    Coding: 0000538
    Shop #: WSC 02327 785 00200
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
    Component: Komfortgeraet H14 0090
    Revision: 00900014 Serial number: 01000382330000
    Coding: 0000243
    Shop #: WSC 02335 785 00200
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0010
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 33
    Mileage: 122159 km
    Time Indication: 0
    Date: 2010.01.19
    Time: 14:50:10
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 B HW: 4F0 035 223
    Component: Amp.-ASK H09 0270
    Revision: 14S00001 Serial number: 02506040013177
    Coding: 0000001
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H07 0040
    Revision: Serial number: 00000000018078
    Coding: 0001103
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
    Component: TSG BF H10 0020
    Revision: 00000000 Serial number: 9‘
    Coding: 0000538
    Address 53: Parking Brake Labels: 4F0-910-801.lbl
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000321
    Shop #: WSC 00409 210 91017
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 33
    Mileage: 122152 km
    Time Indication: 0
    Date: 2010.01.19
    Time: 14:50:09
    Freeze Frame:
    Voltage: 10.97 V
    Count: 241
    Address 56: Radio Labels: Redir Fail!
    Coding: 0100002
  2. Re: Esp malfunction/parking brake
    Lansdale, PA, USA
    0
    OK, here's some advice: Try a legitimate VCDS system as opposed to the pirated one you're got there.
    -Uwe-
    www.Ross-Tech.com
    Satisfaction guaranteed or double your fault codes back!
  3. Re: Esp malfunction/parking brake
    Oct 2009
    Scotland
    1
    Quote Originally Posted by Uwe@Ross-Tech View Post
    -Uwe-
    I wasn't aware it was a pirated one or that you could buy a pirated one as i've read that they need to be licensed interfaces to work?? Will try and get hold of a legit one and do another autoscan.
  4. Re: Esp malfunction/parking brake
    778
    Quote Originally Posted by BIGSSS View Post
    If you bought it from eBay it's 99.9% likely to be a fake/pirated copy.
    visit here for the authorised vendor list. Gendan are a name recommended frequently on here.
    thread closed for the time being, once you've got a legitimate license I'll be happy to reopen.
    on sabbatical
  1. Esp/ park brake fault
    By davey260476 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-12-2010, 01:11 PM
  2. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  3. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  4. ESP off, What's the difference?
    By bquattro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-11-2007, 02:18 AM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
