Thread: Octavia- Central locking keeps locking.
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Octavia- Central locking keeps locking.
    Jan 2010
    Bath
    3
    Hi I have a problem with my electrical central locking on my Octavia Estate 1.9DTI 2003 (53 plate). On Christmas Eve after locking the car with the key ( the battery in the remote fob having run out, so have been using the key ), I could hear the central locking was operating the locks trying to unlock and lock repeatedly this would stop after a minute and continue a few minutes later, this cycle went on for few hours. I was worried the battery would drain overnight, so disconnected the earth connection and left the car overnight disconnected.
    All was fine, until last Wednesday, when the same thing happened, and has continued ever since. Plus, now the doors automatically lock when the ignition is on and we are driving along. When the central locking button on the door arm rest is depressed this unlocks all doors, but the doors lock straight away again. We now disconnect the battery whenever the car is parked.
    I have removed the battery from the remote key fob, no real difference.
    I have checked my owners manual for fuse assignment list, way no 6 is designated central locking control unit but this is not fitted. Way no 38 is designated luggage light central locking, remote fuel filler 10A, or central locking and interior light 15A, I do have a fuse in this position but it is 1.5A, not 15A may be a misprint as the same error occurs on most of the ways 38 to 43 i.e. out by factor of 10. I have removed fuse 38, central locking does not work, nor the filler flap but interior lights etc continue to work.
    Can anyone confirm if it is acceptable to use the car without this fuse in place. Will this prevent the the system trying to lock and unlock and therefore drain the battery. Can I now leave the battery connected at all times and manual lock the doors. Any thoughts on what the problem is and how it may be resolved without going to the main dealer and costing the earth. The omens are not good having reviewed similar Octavia problems on the net. Any help would be greatly appreciated.
  2. Re: Octavia- Central locking keeps locking.
    May 2008
    Get is scanned for faults with VCDS for starters.
    Could be a water leak into one of the front door control modules?
  3. Re: Octavia- Central locking keeps locking.
    Jan 2010
    Bath
    3
    Quote Originally Posted by Issac Hunt View Post
    Hi Issac
    Many thanks for your response.
    Probably best if I obtain the services of an auto electrician, rather than go to a main dealer.
    Thanks again.
    mawb
  4. Re: Octavia- Central locking keeps locking.
    May 2008
    Just find someone near you with VCDS who can scan it for you for nothing!
    Check the location thread on here for someone near you.....
  5. Re: Octavia- Central locking keeps locking.
    sheffield
    0
    i've got the same problem and its only started happening since the bad weather
  6. Re: Octavia- Central locking keeps locking.
    Jan 2010
    Richmond
    0
    Hi mawb,
    Have you managed to make any progress with this, only my 03 Octavia Elegance TDI has just started doing this too. I have virtually identical symptoms, summarised as follows:
    • The car locks itself (whether in use or stood dormant, ignition off et al) without any human intervention whatsoever. When it does this, generally any attempt to unlock it results in the car immediately re-locking itself.
    • When already locked and red LED on door is flashing, all of a sudden (again without any deliberate external trigger) it will occassionally go through a cycle of repeatedly going into Safe locked mode (i.e. red LED off, so not deadlocked), then a number of seconds later coming back out of Safe locked mode (i.e. red LED flashing again, so re-deadlocked).
    Incidentally, car battery voltage is all fine (checked that already), so it's all really annoying. I currently have the battery earth lead disconnected but will try taking the central locking fuse out (if I can get it to lock in Safe mode without the deadlocks!). That will hopefully at least enable me to still safely lock (and therefore use) the car.
    Please can you post an update when you manage to make progress with yours.
    Also, if anybody else reading this can shed any light on where to start looking to sort this, please advise - all input gratefully received.
    Many thanks,
    Lampman
  7. Thanks Mawb thanked for this post
  8. The Following User Says Thank You to Lampman For This Useful Post:
    Mawb (25-01-2010)
  9. Re: Octavia- Central locking keeps locking.
    sheffield
    0
    ive found that if i unlock the rear door and open it before it locks then unlock it while open all doors stay unlocked
  10. Re: Octavia- Central locking keeps locking.
    Jan 2010
    Richmond
    0
    Funny you should mention that, geoffrocks. However, with mine, if I am quick enough to open the driver's door when attempting to unlock the car, then keep the (driver's) door open, the self-triggering locking stops completely for as long as the door is open. However, if I try the same trick with any other door, the central locking still re-locks itself.
    Obviously, keeping the driver's door open all the time is not the answer. I have taken the central locking fuse out now, but interestingly the boot lock motor still has a tendency to self-lock, albeit after anything up to a couple of minutes. Acc to the (not very good) schematic diagram in the workshop manual (i.e. the one produced by a well-known publisher that will remain nameless!), the boot lock motor appears to be powered direct from the Convenience Unit, separate to the rest of the central locking system. Does this all suggest the problem lies in/with the Convenience Unit? If so, where exactly is the damn thing and do they suffer any specific common ailments (i.e. water ingress, dry joints that can be easily resoldered, etc.)?
    Thanks in anticipation for any tips / info,
    Lampman
  11. Re: Octavia- Central locking keeps locking.
    sheffield
    0
    should call it an inconveniance unit, contacted Skoda uk they dont want to know just pass the buck to local dealer, my car is parked on a steep drive wonded if that had anything to do with it as water could get in to the boot door and its possible it could get into the lock
  12. Re: Octavia- Central locking keeps locking.
    sheffield
    0
    by the way mine is a 53 Octavia Elegance TDI Estate
  1. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-06-2014, 12:19 PM
  2. Remote? Central Locking Unit
    By ImCammers in forum Golf MK4 - 1999 - 2004
    Last Post: 13-09-2009, 07:08 PM
  3. Problems connecting Remote Central Locking ...2004 Polo E
    By andy4976 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-06-2009, 10:24 AM
  4. Replies: 1
    Last Post: 19-01-2008, 11:06 PM
  5. weird Golf central locking problem!
    By daft in forum Golf MK4 - 1999 - 2004
    Last Post: 21-02-2006, 04:49 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
