Thread: Touran Fuse Box in engine compartment
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Touran Fuse Box in engine compartment
    1841 Post(s)
    Pop in and see me one day at work and I will work out what you need and print or email them or when you have enough posts to send me a PM, send me your reg number and email.
    VAG would struggle to provide a diagram as it would have to be printed virtually for each car that was produced as there are massive year, model and spec variations.
    VW Audi Seat Skoda Specialists | Parts Service Modifications
  2. Re: Touran Fuse Box in engine compartment
    Oct 2006
    Sunny slightly hilly Norfolk
    Likewise sorry to hijack the thread but I've got an 08 TDi Touran which has the power sockets that are only live with the ignition on. Is there any way of changing them so that they remain on until the key is taken out of the ignition like I had on my 06 Touran? I need to keep power to them for my kids DVD player.
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
  3. Re: Touran Fuse Box in engine compartment
    1841 Post(s)
    In May 2008 the feed for the power sockets moved from fuse 27 line 30a in the dash side fuse panel to fuse 30 on the circuit referred to as 75a which is fed from the X relay that is controlled by the ignition circuit. There is a 1.5-mm red/black wire to fuse 30 that could be moved to a permanent live feed 30a such as the one provided by the 80 amp fuse at position 5 on the front of the under bonnet fuse box which provides line 30a power to the dash fuse box at fuses 20, 21, 45, 46, 47, 49, 50, 51 and 52 and there may be a spare slot on the bus bars that a competent specialist who knows about these systems and has the proper connections/crimps, could tap into easily.
  4. Re: Touran Fuse Box in engine compartment
    May 2010
    Swindon, UK
    My apologies to trespass on this thread. My problem is my ac clutch not engaging. Can you help to locate the relay or fuse for ac clutch?
  5. Re: Touran Fuse Box in engine compartment
    1841 Post(s)
    It does not have a mag clutch, constant drive compressor......
  6. Re: Touran Fuse Box in engine compartment
    May 2010
    Swindon, UK
    Hi mate. Sorry Im no expert on this. Can you please explain in laymans terms please. Is it aircondition clutch compressor you referring to?
  7. Re: Touran Fuse Box in engine compartment
    #17
    Feb 2017
    SWINDON ENGLAND
    hi, I,am looking for the fuse for the rear wiper motor on my 2.0 04plate fsi touran, also the boot is not opening but the dash states it is open when not. I think the problem may be related. can anyone help please
  8. Re: Touran Fuse Box in engine compartment
    #18
    1841 Post(s)
    That is a rare Touran you have there, in a few years time it will become worth more than it is now when it can be used freely in Toxicity zones where decade newer diesel Touran will get charged at least £10 a day; mind you that is if the boot floor hasn't rusted through and written it off... Yes the two faults are related, the wiper motor washer jets tube leaks into the wiper motor and rots it and the water runs out onto the boot lock and switch assembly where it does the same. The fuse you are looking for is number 29 on the under dash fuse panel but I would not be surprised if it was intact.
  1. oil warning signal
    By ger83 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 07:20 PM
  2. VW Golf 1.6 FSI Engine noise
    By David Farmer in forum Golf MK5 - 2004 - 2009
    Last Post: 13-05-2009, 11:10 AM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. A4 95/96 Engine Management Fuse blowing
    By PClements in forum Archive posts
    Last Post: 01-11-2007, 09:46 PM
  5. Answers From The Oil Expert Part 2
    By oilman in forum Archive posts
    Last Post: 22-10-2007, 08:30 AM
