Thread: OBD diagnostic connector NO power
Results 1 to 9 of 9
  1. OBD diagnostic connector NO power
    Dec 2009
    kilwinning
    Hi all
    Haveing some issuses with my Seat Alhambra 2000 19tdi 110 ps
    No : ABS light
    No : MANAGEMENT light
    Cruse not working
    Now when i plug in the code reader it does not power up
    Tryed same reader in my skoda works fine
    Any ideas
    Fraser
  2. Re: OBD diagnostic connector NO power
    Check fuse 19 in the fuse box
  3. Re: OBD diagnostic connector NO power
    Dec 2009
    kilwinning
    Could this be a ECU fualt ?
    on the ECU does the last letter mean any thing or is it that as long as the numbers match
    fraser
  4. Re: OBD diagnostic connector NO power
    If the diagnostic port has power you should be able to access other control units,
  5. Re: OBD diagnostic connector NO power
    Dec 2009
    kilwinning
    plug in a launch code reader
    tryed it in my skoda works fine?
    do i need a diffrent type of code reader what type
    cheers
  6. Re: OBD diagnostic connector NO power
    I shouldn't think so,if it works for the Skoda it should work on Seat,have you checked the fuse i mentioned?
  7. Re: OBD diagnostic connector NO power
    Dec 2009
    kilwinning
    yes checked all the fuses drop the fuse box down checked the hevy fuses at the back
    checked the wire out the back of the fuse box had not been cut
    checked the wires at the back of the port
    red wire had been striped back and retaped the reason i dont know
    thanks for your reply
  8. Re: OBD diagnostic connector NO power
    You should have power on pin 16
  9. Re: OBD diagnostic connector NO power
    Dec 2009
    kilwinning
    thanks Kenny
    no power at pin 16 checked fuse 19 again power across the fuse
    cut wire to pin 16 at port and gave it 12v feed ...........reader works
    faults
    H1 46a3
    H2 E
    H3 0122 0129c
    H4 --
    still no management light or abs light
    can seem to fine the meaning of these codes as i never got the book with the reader lol
    thought i seen a section on the forum for codes cant fined ot now brain freeze i think its
    any pointers
    Fraser
  1. Power to diagnostic port
    By AJC2008 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 03-04-2009, 10:05 AM
  2. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  3. diagnostic power
    By barking71 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-11-2007, 06:43 PM
  4. How does the Quattro system work?
  5. Power born from passion The new Audi TT Coupé
    Last Post: 16-06-2006, 07:30 PM
