Thread: 1.9 TDI AJM Wont start when hot ! :(
  1. 1.9 TDI AJM Wont start when hot ! :(
    Feb 2009
    10
    I had my question on the back of another thread, But thought i'd stick it on here to be be clearer..plus i've since found the cure !!
    And some other members may actually find it useful !
    I'll start from the beginning
    Im 99% sure 4 months ago the car use to start from cold a bit rough, I.e. Sometimes it needed some gas.
    So i did a service and changed the glow plugs (sadly for halfords ones, should have known better). However when removing an old one, the casing of it snapped. But the glow plug did not drop into the engine.
    a month ago i got my brother to take the head off. The glow plug was removed and threads checked at a machine shop.
    The Head was then refitted with a new head gasket and cam belt. (crank locking tool used and a drill bit for the top cam) Car ran well for a week (however again the little bit of rough cold start up happened on the odd occasion)
    But then this problem developed
    once the car is warm and turned off it will not restart. It turns over for ages and doesnt start, sometimes it coughs and then starts up.
    To sum up the work so far.
    Symptoms earlier this year,
    - A little poor on cold start up - So glow plugs changed, however the casing of one broke in the head
    So in October
    - Head removed, glowplug removed and threads checked at machine shop.
    - New Headgasket insalled (stupidly reused the headbolts, do NOT do this as there only 4 each from the dealer !)
    - New timing belt
    - Service done, oil and fuel filter.
    A week later the car stopped starting from hot..it only liked to start from cold or luke warm, and sometimes it isnt too happy about that.
    Parts Fitted with no cure
    - New Starter motor (GSF)
    - New MAF (OEM) (more of a service item than a fix)
    - New Temp Sensor (OEM)
    - New Relay 109 (OEM)
    - New Fuel Filter Tap (GSF)
    - Second hand Wiring harness for injectors installed and the symptoms did not change
    - Second hand injectors, Was told mileage was 50-60k however take that with a pinch of salt
    - All new stretch bolts used and seals on the injectors.
    - Second hand Tandum pump
    - Had it on VAGCOM numerous time with no fault codes.
    Finally,
    A friend of mine gave me some second hand Crank and Cam semsors and this solved my problem !
    Im 99% sure its the crank sensor.
    So if your having poor starting problems its definatly worth a look. I think there only about 65 from the dealers and are dead easy to change.
    The sensor is located to the right of the oil filter housing.
    Hope that helps someone.
    Matt
    Btw if you want to read through my 13 page thread to see the other ideas and suggestions we had to cure the problem see here:
    http://www.vwaudiforum.co.uk/forum/s...ad.php?t=84064
    Last edited by MagicMat; 13-01-2010 at 03:10 PM. Reason: Found a cure to my problem !
  2. Re: 1.9 TDI AJM Wont start when hot ! :(
    Feb 2009
    10
    Edited see above post
  3. Re: 1.9 TDI AJM Wont start when hot ! :(
    Feb 2009
    10
    **Thread editied
  4. Re: 1.9 TDI AJM Wont start when hot ! :(
    Feb 2009
    10
    Bump for this thread,
    I've edited the first post as i found a cure for my problem. Hopefully it will help other members in the future
  5. Thanks turpal thanked for this post
  6. Re: 1.9 TDI AJM Wont start when hot ! :(
    Southampton, UK.
    21
    Nice, concise digest. Thanks!
    2003 VW Golf Est TDI 130 (ASZ) 6 speed
  7. Re: 1.9 TDI AJM Wont start when hot ! :(
    Feb 2009
    10
    why thank you !
    people always say they will come back and post their results but they dont always, but since i recieved so much help i wanted to give something back
    So hopefully it will help someone
    Matt
  8. Thanks Mike Smith, hibbsy21 thanked for this post
  9. The Following 2 Users Say Thank You to MagicMat For This Useful Post:
    hibbsy21 (05-06-2010), Mike Smith (21-11-2010)
  1. 2006 Jetta 1.9 TDI Warm Start Problem
    By MrXee in forum New Jetta - 2005 - 2013
    Last Post: 19-08-2010, 07:44 PM
  2. 2006 t5 1.9 tdi, white smoke on start up
    By chicargo in forum The Commercial Range
    Last Post: 08-08-2009, 11:42 PM
  3. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  4. Hot starting, 1.9 TDI Sharan.
    By 1.9 TDI Sharan in forum Archive posts
    Last Post: 10-12-2007, 12:31 AM
  5. 1.9 TDi harsh with vibration or are they all like that?
    By schomosport in forum Archive posts
    Last Post: 02-12-2007, 01:11 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
