Thread: Golf mk5 bkd engine misfire on tickover 2.0 gt tdi
  1. Golf mk5 bkd engine misfire on tickover 2.0 gt tdi
    Sep 2012
    Birmingham England
    Please help I'm having problems with my engine stuttering on tick over from cold start I have had it on vag com no codes all injectors are within parameters but it is fine when driving there is no difference when I push clutch in its had egr valve cleaned maf checked temp sensor reading fine fuel filter changed numerous bottles of injector cleaner through it need help driving me mad!!!!!
  2. Re: Golf mk5 bkd engine misfire on tickover 2.0 gt tdi
    Sep 2013
    dublin ireland
    i feel for you man im on the same boat im booked in for ecu map tomorow did you get anywhere with this get rid of the stu stu stu stuttering ????? its rekin my head aswell melter takin all the plesure out of the car have also had the warm start problom after replacing temp senser grrr
  3. Re: Golf mk5 bkd engine misfire on tickover 2.0 gt tdi
    Sep 2012
    Birmingham England
    Mate the problem with hot starting is the starter motor I changed mine and the problem went away, and your stuttering problem is the dual mass flywheel change them both and my problem went away hope this helps
  4. Re: Golf mk5 bkd engine misfire on tickover 2.0 gt tdi
    Sep 2013
    dublin ireland
    cheers man seems simple yet expensive but dont think the dmf is gone 3 independent garages advised me it was an injecter after hooking it up to comp but after swaping (say 2 was the problem injecter) with number 1 number 2 was still out of sync with the rest and number 1 fine ... these cars are a nightmare .. my dmf isnt knocking it is only the car vibrating when idle and is going through gears no bother and pushing on clutch dosnt get rid the shake ..
  5. Re: Golf mk5 bkd engine misfire on tickover 2.0 gt tdi
    Sep 2012
    Birmingham England
    Have you changed the injector loom ?
  6. Re: Golf mk5 bkd engine misfire on tickover 2.0 gt tdi
    Sep 2013
    dublin ireland
    Quote Originally Posted by Ianr703 View Post
    no didnt change inj loom im tryna figure out the problem b4 i go throwing my wallet around this sites great for info anthor user said he resolved the problem by adjusting the timing belt tooth by one tooth and his car sorted but the problem was there b4 i got my tbelt done last week and its still there
  7. Re: Golf mk5 bkd engine misfire on tickover 2.0 gt tdi
    Sep 2013
    dublin ireland
    Quote Originally Posted by 8loopy8 View Post
    idle wobble jutter sorted out by 1 tooth on belt tdc tools fixed problom yeheyy like a new car
  1. Please Help lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    By ijvader69 in forum Golf MK5 - 2004 - 2009
    Last Post: 18-11-2013, 12:06 AM
  2. misfire and smoke on startup tdi bkd
    By nokia_aid in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-04-2013, 06:45 PM
  3. 2.0 tdi bmn / bkd engine idle misfire/judder PLEASE HELP!!!
    By GTRUSS in forum Golf MK5 - 2004 - 2009
    Last Post: 09-09-2012, 04:34 PM
  4. Please Help mk5 golf gt tdi 140 bkd 2005 problems
    Last Post: 17-05-2012, 08:08 AM
  5. Golf MK5 engine misfire deaccelerating
    By 19carmen in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2010, 09:03 AM
