Welcome to the VW AUDI Forum - VWAF.
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
  1. #1
    0
    QUESTION electric cooling fan staying on?
    Hi guys,
    just had my 2.4ltr (2001 plate) serviced by an independent on the weekend.
    he said the only thing he found problem wise was that the secondary cooling fan after about 10 mins or so was comming on and then staying on constantly and not switching off (unless the ignition is turned off). He had hooked the car up to the VAG tool but said the car was comming back clean - no fault codes comming back at all.
    the car temp gauge is running at 90 as it always has.
    I have got a brake fluid change at an audi dealer this saturday (£49!!) my independent suggested i get them to see if they can find fault but with audi labour at £104/hour im bit unwilling to
    so a few questions for you guys:
    1. Any ideas??
    2. Apart from perhaps an increase in petrol consumption ok to continue as is?
  2. #2
    Nov 2008
    Cramlington,Northumberland
    3
    Re: QUESTION electric cooling fan staying on?
    Is your Air Con turned on when this happens?Also,do you have an outside temperature sensor? If so does it work,as may all be connected.
    Alan.
    A6 Avant Le Mans
  3. #3
    0
    Re: electric cooling fan staying on?
    i tried it again this morning without the air con on and the fan didnt come on.
    on the weekend i did have the air con on (for heating) and the fan stayed on once the engine had got to operating temp.
    It does have an outside temp but that is reading correctly
  4. #4
    Nov 2008
    3
    The VW commercials do this also when the Air Con is switched on,the fan cuts-in.If its something it never used to do,at least this points the diagnosis in the right direction.Maybe you never noticed it b4?
    Alan.
    A6 Avant Le Mans
  5. #5
    0
    i have noticed the fan before as when it cuts in its like a jet engine but it always used to switch on and offf as required. now its just on all the time until i turn the car off.
    perhaps tonight ill switch the air con on then after a while switch it off - the fan should switch off right?
  6. #6
    Nov 2008
    3
    Yes it should.I dont rekon it should run constantly with the air con `on`though.
    Alan.
    A6 Avant Le Mans
  7. #7
    0
    so i took it for a run last night got the engine up to operating temp (90C on the gauge) deliverately didnt turn on the AC system. once at 90C gave it about another 10 mins then switched the AC on. outside temp was 11C so the system was blowing mildly warm air. no sign of the 2nd fan cutting in. was in the car for about 25mins
    this morning ran the ac from start up - outside temp was 9c so warmer air came out once engine reached operating temp. 15 mins or so drive no sign of the 2nd fan cutting in
    now im wondering if i should let audi spend the 1 hour/£104 investigation time on saturday looking into the "fault"
  8. #8
    Southern County Softy
    39
    Aircon on will run the fan, switch off the aircon, get the engine hot and see if the fans cut in and out.
    A4 2.5 tdi QS (mapped)
  9. #9
    0
    thanks.
    will try that this evening
    once at 90C should it start cutting in at normal town drving (30-40mph) or will i need to give it a "run" down the dual carriage way?
  10. #10
    39
    I would run the car at fast idle with the bonnet up so you can see the fans.
    The fans won't cut in untill the engine is over 90C, once over 90C the fans should run at slow speed, if the engine continues to get hotter the fans should run at double speed.
    You could also have a dodgy coolant temp. sensor, thermoswitch in the rad or fan relay..
  1. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  2. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  3. Electric cooling fan noisy
    By Ikule in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-06-2009, 04:52 PM
  4. Help Passat electric cooling fan
    By jonathan bees in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2008, 11:12 PM
  5. pd 130 electric cooling fan
    By c12weddi16 in forum Passat - Archive Topics
    Last Post: 11-03-2007, 04:10 PM
Back to top
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Copyright: VW Audi Forum is an AUTHORISED DEALER for the Surf City Garage range of car care products. All Surf City Garage images are "Copyright" of Surf City Garage
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
- www.vwaudiforum.co.uk - www.vwaf.co.uk - www.vwaf.co.uk - www.vwaudiforum.co.uk -
/p
