Welcome to the VW AUDI Forum - VWAF.
Results 1 to 10 of 20
  1. #1
    Nov 2009
    stalbridge england
    2
    A4 problem code 00575
    I have a 1999 A4 TDI 1.9. When you boot it the engine splutters at about 2800 revs, then only has reduced power until the engine is switched off. My spanner man has identified the problem as code 00575 (Intake manifold pressure deviation from desired value intermittant). Has anybody any ideas on this problem please.
  2. #2
    Jun 2008
    1
    Re: A4 problem code 00575
    Hi, Sounds like a turbo or boost problem, check all the pipes between the turbo and intercooler for splits and then between the intercooler and the inlet manifold. Are you getting any black smoke when driving? take off the hose from the front of the turbo and check if there is lots of oil in the pipe. with the engine cold and it must be cold! look in the front of the turbo and inspect the fan blades for damage and the casing around the blades for scraping. use your index fingure on the end of the shaft with the fan blades on ther should be only a minute amount of play side to side up and down, Then try and pull the shaft in and out, any paly in and out and the turbo is knackered.
    Hope it is just a split pipe or just a pipe popped of and not the turbo!
  3. The Following User Says Thank You to martinA4passat For This Useful Post:
    Geoff Gill (16-11-2009)
  4. #3
    Nov 2009
    stalbridge england
    2
    Smile Re: A4 problem code 00575
    Thanks fo that. There is black smoke when you boot it, the same as most other diesels. I will check out the things you have mentioned. Like you say hopefully just a pipe. Thanks again
  5. #4
    Aug 2008
    0
    I had the same thing happen to me recently, as well as the black smoke what is your coolant temp like ??
    Mine was running about 15c too low and it turned out to be a hole in the pipe leading to the intercooler, hope this helps
  6. The Following User Says Thank You to DJJoker For This Useful Post:
    Geoff Gill (17-11-2009)
  7. #5
    Aug 2008
    6
    Hi, I'm really interested in the "holed intercooler pipe" theory. I have had the intermittent loss of power issue with my 2.5 tdi for 2 years now (i am very patient). It is accompanied by a fault code of 000575 "inlet manifold control pressure exceeded" & during my ownership it has never reached optimum operating temp. I usually drifts between 65 & 75 deg c. Wher exactly was the hole in the intercooler pipe? & did this result in over or under boost?
  8. #6
    Aug 2008
    0
    I dont have my audi anymore but from memory the hole was in the lower pipe leading to the intercooler on the underside. My mechanic and I think it was caused by road debris bouncing up at high speed due to the guard being absent!
    Regards
    DJJ
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 09:21 PM
  3. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  4. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 08:26 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
Back to top
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Copyright: VW Audi Forum is an AUTHORISED DEALER for the Surf City Garage range of car care products. All Surf City Garage images are "Copyright" of Surf City Garage
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
- www.vwaudiforum.co.uk - www.vwaf.co.uk - www.vwaf.co.uk - www.vwaudiforum.co.uk -
/p
