Thread: low engine power from cold
Results 1 to 10 of 14
  1. low engine power from cold
    Aug 2008
    hi all
    just looking for some info or is that insperation
    im looking at a audi a6 2006 2.0tdi with a low engine power when cold ive driven it and managed to stall it while pulling out a junction drive it for 5 mins and its got its power back.
    no black smoke or anything like that
    im thinking of looking at coolant temp from cold, some sort of fuel delivery issues,boost pressure and anything else you chaps can think of
    the owners not the kind to boot it off the line from cold it just seems to sluggish think my transit would have a better start from cold
    thanks in advance for any help
    paul
  2. Re: low engine power from cold
    1836 Post(s)
    First of all a fault code read, guessing is not a good starting point.
  3. Re: low engine power from cold
    Aug 2008
    thanks crasher
    will be doing that first but ive scanned this car b4 and its never shown a fault but yes it could have one now
    so i just want to be armed with as much info as posible when i go to look at it
    thanks again
    paul
  4. Re: low engine power from cold
    May 2007
    knee deep in clunge
    14 Post(s)
    manual or multitronic?
  5. Re: low engine power from cold
    Aug 2008
    hi
    its a manual
    thanks paul
  6. Re: low engine power from cold
    Aug 2008
    hi all
    well i looked at this A6 today and as i thought no faults found
    Thursday,08,October,2009,09:47:05:08836
    VCDS Version: Release 908.0
    Data version: 20090911
    Chassis Type: 4F0
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56 61
    62 72 76 77
    VIN: WAUZZZ4F66N141258 Mileage: 115020km/71470miles
    01-Engine -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BLB.lbl
    Part No SW: 03G 906 016 HS HW: 028 101 255 7
    Component: R4 2,0L EDC G000SG 9673
    Revision: --H02--- Serial number:
    Coding: 0000072
    Shop #: WSC 00202 210 50776
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
    Component: ESP 8.0 front H04 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020855
    Shop #: WSC 02325 785 00200
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10604000337856
    Coding: 0000145
    Shop #: WSC 00505 210 80779
    Part No: 4F0 910 131 D
    Component: FBSAUDIC6 EZS H45 0070
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H39 0040
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 732 J HW: 4E0 035 729
    Component: Interfacebox H43 3460
    Revision: 00000000 Serial number: 350AU067645696
    Coding: 0001002
    Shop #: WSC 02335 785 00200
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H03 0050
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 J
    Component: KLIMABETAETIGUNGH12 0170
    Revision: 00000030 Serial number: 00000030090588
    Coding: 0001300
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 D HW: 4F0 907 279
    Component: ILM Fahrer H15 0190
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0001101
    Part No: 4F2 910 113
    Component: Wischer AudiC6 H04 0150
    Coding: 00062736
    Shop #: WSC 02335
    Part No: 4E0 910 557
    Component: REGENLICHTSENSORH11 0050
    Coding: 00141886
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBF8049647
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    02244 - Button in Control Head is Stuck
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 116
    Mileage: 113861 km
    Time Indication: 0
    Date: 2009.09.22
    Time: 08:26:55
    Freeze Frame:
    Bin. Bits: 00001000
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH29 0280
    Revision: 08H29000 Serial number: 0037LD0CN41+
    Coding: 0013381
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H07 0230
    Revision: 00H07000 Serial number: 90026060110366
    Coding: 0102042
    Shop #: WSC 02323 785 00200
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 A HW: 4F0 920 980 M
    Component: KOMBIINSTR. M73 H17 0660
    Revision: 00100000 Serial number: 4PX571G16
    Coding: 2052443
    Shop #: WSC 00202 210 80978
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H11 0070
    Revision: 11 Serial number: 1300806117009F
    Coding: ECEE53C41B3104
    Shop #: WSC 02334 785 00200
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 887 T HW: 4E0 919 887 D
    Component: MNS ECE H47 1030
    Revision: 00000000 Serial number: 364AU067523687
    Shop #: WSC 02324 785 00200
    1 Fault Found:
    03183 - Data Media not Compatible
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 112
    Mileage: 113797 km
    Time Indication: 0
    Date: 2009.09.21
    Time: 17:58:38
    Freeze Frame:
    Hex Value: 0x4AB7
    Hex Value: 0xBF08
    Hex Value: 0x0000
    Hex Value: 0x0000
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0120
    Revision: 00000000 Serial number: bD)
    Coding: 0003610
    Shop #: WSC 02327 785 00200
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01010004750000
    Coding: 0131835
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H10 0350
    Revision: 33S00001 Serial number: 01701060207443
    Coding: 0000103
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000180951
    Coding: 0001104
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0120
    Revision: 00000000 Serial number: (0)
    Coding: 0003610
    Address 53: Parking Brake Labels: 4F0-910-801.lbl
    Part No SW: 4F0 910 801 HW: 4F0 907 801
    Component: EPB C63C0030 H03 0030
    Coding: 0000111
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4F0 035 541 E
    Component: TUNER EU/US/RDW H42 0620
    Revision: 00000000 Serial number: 352AL067616354
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000000267
    Part No: 4F0 915 105 C
    Component: von VA0 1601041615
    Coding: 344630393135313035432056413031363031303431363135
    Shop #: WSC 00000 512 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0003074
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0003074
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
    Component: Parkhilfe 4-Kan H09 0030
    Revision: 00H09000 Serial number: 11720602001378
    Coding: 0200116
    Shop #: WSC 131071 1023 2097151
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 L HW: 4E0 862 335
    Component: Handyvorb2 H20 1120
    Revision: 00000000 Serial number: 00000005196875
    Coding: 0010920
    so i started looking in measuring blocks at temps and every thing looked ok checked injected quantity thats ok also injector duration and that fluctuated a little.
    then found channel 044 and that showed maf readings that was high spec is 180-300 at idle actual was approx 450
    so fitted a recon maf from audi (£89) rechecked channel 044 and the reading was down to just under 300 (car has been remapped) took it for a test drive and it seems better but will know more in the morning
    thanks paul
  7. Re: low engine power from cold
    1836 Post(s)
    Well I have a saying, “no power, no codes, new AMM”.
  8. Re: low engine power from cold
    May 2007
    knee deep in clunge
    14 Post(s)
    Agree Crasher, it seems the old air mass meter has risen its ugly head again and having never Replaced one single air mass for 2.0 pd I'm not convinced either.Its the only reliable part on this engine lol
  9. Re: low engine power from cold
    Aug 2008
    well well well had a call today and its still the same when cold.
    not sure what it could be now its due for a service in 3500 miles and timing belt. had the air filter out and that seems to be ok for needing new one at service.
    the car is driven out the garage most mornings switched off house locked up(5 mins) then car is driven for 5 mins about a mile engine is now warm car drives ok after that
    so what else can cause it to be sluggish when cold
    thanks for the help
    paul
  10. Re: low engine power from cold
    May 2007
    knee deep in clunge
    14 Post(s)
    Its most likely to be my old friend egr doing its job as its supposed to, and this will sap power from cold for obvious reasons and also affect air mass intake measurements for fuel/air demands from cold.
    If were talking no power then yes there's a problem but if we are talking reduced power until engine temp increases then the obvious conclusion is correct driving method and you assume you have a fault is more than likely the problem full stop.Regards A8
  1. Please Help Battery + Climate Control Unit + Engine + What's next?
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2009, 07:39 PM
  2. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  3. AAZ engine. no low down power.
    By arwel in forum Golf MK3 - 1993 - 1999
    Last Post: 16-03-2008, 04:11 PM
  4. Answers From The Oil Expert
    By oilman in forum Archive posts
    Last Post: 05-10-2007, 03:25 PM
  5. Power born from passion The new Audi TT Coupé
    Last Post: 16-06-2006, 07:30 PM
