Thread: injected quantity automatic transmission
  1. injected quantity automatic transmission
    PADDYPONCHERO Guest
    I've adjusted injected quantity before on manual cars no problem.
    Now I have a 98 passat with an auto box the injected quantity is different in drive, park and neutral.
    In drive the injected quantity is ideal and engine runs smoothly, switch to park or neutral and it drops to 0.8mg and the engine obviously stutters.
    Anyone know the adaptation for the auto transmission.
  2. Re: injected quantity automatic transmission
    Aug 2008
    try looking for gearbox faults sounds like its not disengauging drive could also be due for a gearbox oil change
    paul
  3. Re: injected quantity automatic transmission
    PADDYPONCHERO Guest
    Quote Originally Posted by saabsalltheway! View Post
    paul
    Thanks for the reply. There are no gearbox faults reported, oil changed recently and definitely disengaging, its like theres a lower injected quantity for when the gearbox is disengaged which makes sense as theres a lower load. If it was just a tiny bit higher it would tick over perfectly.
  1. Please Help Oil pump on automatic transmission
    By kathaliner in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-11-2009, 08:25 PM
  2. How does the Quattro system work?
  3. Audi A4 '99 Tdi Automatic transmission problems
    By danas35 in forum Audi A4 - Archive Topics
    Last Post: 26-10-2006, 05:04 PM
  4. VW Passat Automatic transmission problems?
    By maverick777 in forum Passat - Archive Topics
    Last Post: 21-09-2006, 02:32 PM
  5. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
