Thread: key fob problem
  1. key fob problem
    Hello all,
    I have a weird problem with my key fob. I cannot unlock the car using the keyfob. The fob still locks the car and operates the tailgate but refuses to do anything when the unlock button is pressed. I can unlock the car with the key, start the engine and drive normally.
    Also the red light on the key fob does not flash when I press the key, however as the key fob locks the car I am assuming that the battery is working.
    Can anyone help? (it is the 3 square button type key fob)
    Thanks in advance.
  2. Re: key fob problem
    Aug 2008
    It's obviously transmitting OK if you can lock the car, so it must be the little 'unlock' microswitch on the circuitboard that has bust. Try Ebay for a replacement as they are easy to reprogram when you have another.
  3. Re: key fob problem
    Gwent
    Quote Originally Posted by limecc View Post
    Try to get the same part no. and frequency as the existing key, if different, it probably won't work
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Problem with Advanced Key & One-Touch Memory
    By NeilA8 in forum A8 - S8 - V8
    Last Post: 29-11-2013, 09:51 AM
  2. Replies: 28
    Last Post: 02-11-2009, 11:08 PM
  3. 1999 new Beetle US Key and key fob
    By dewman in forum Beetle 2000-
    Last Post: 29-01-2008, 09:42 PM
  4. 1999 Golf Alarm Key Fob Question
    By mdcooper in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-05-2007, 10:06 PM
  5. 2000 Mk4 Golf Remote Key Fob
    By mwshy in forum Golf MK4 - 1999 - 2004
    Last Post: 24-05-2007, 07:38 PM
