Thread: Change a cigarette lighter fuse
  1. Change a cigarette lighter fuse
    Sep 2009
    Glasgow UK
    Hi all
    I have a MK V GT TDI, and my lighter is jammed in, I think it might just be a fuse problem (hoping its a fuse problem) Does anybody know how i go about replacing the fuse, where its located etc and where do i buy a new fuse.
    Cheers in advance
  2. Re: Change a cigarette lighter fuse
    Jul 2009
    malta
    I have a similar problem.
    I have a Glof mk5 2005 Sport (1.9tdi) and the cigarette lighter looks brand new, filament is still clean. the problem is that the coil wont heat up. I tried it with the engine running and the engine off and there was no difference ...
    Anyone can help pls?
  3. Re: Change a cigarette lighter fuse
    Dec 2006
    Open the drivers door to get to the fuse box, -- Then remove the plastic panel at the end of the dash..
    (you should be able to get your fingers into the bottom to "pop" it off.
    I think it was Fuse 24 or Fuse 26 ??
    Rick
  4. Re: Change a cigarette lighter fuse
    Sep 2009
    Glasgow UK
    Hi folks
    I managed to get it sorted, I changed the fuse ( I have temporarily put a 30amp fuse in) but will source a 25 amp fuse first chance I get. The lighter popped straight out as soon as i started the engine.
    Cheers for your help
    Gary
  5. Re: Change a cigarette lighter fuse
    Jun 2009
    swindon Uk
    Quote Originally Posted by garydm140vwgolf View Post
    Hi all
    Cheers in advance
    Hi, I had blown fuse on the ciggie lighter ......so easy to replace, you can get all the info from your hand book p84, but if you haven't got one..remove the panel nr the drivers door, you have to open the door to get at it. (vw key fits perfectly). I got replacement fuses at Halfords, its the spade type...about a quid I think. 25 amp fuse and its located in fuse holder no. 24.
    tip..use the little extraction tool on the removable cover to get the fuse in and out!
    good luck.
  1. Audi A6 1999 Avant Rear Cigarette lighter fuse??
    By J R Barnett in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-11-2010, 02:08 PM
  2. Known fault - Cigarette Lighter
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 12-09-2009, 06:31 PM
  3. 2006 A6 Avant 2.7TDI Quattro - Cig Lighter Fuse
    By Luapno in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-07-2009, 08:50 PM
  4. No Power to Cigarette Lighter
    By Jason101 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-06-2008, 06:16 PM
  5. Cigarette Lighter (Drivers) What fuse? (bora uk)
    By mrhaun77 in forum Bora - 1998 - 2005
    Last Post: 15-01-2007, 12:13 AM
