Thread: Engine oil in the diesel filter a3 1.9 tdi
  1. Engine oil in the diesel filter a3 1.9 tdi
    Aug 2009
    ballymena antrim
    Hi, i own an 05` A3 1.9 TDI, when changing the fuel filter yesterday i noticed it had engine oil in it. I then run the return fuel line into a clean jar and found the fuel from the tank also contaminated with engine oil, has anyone had this problem and found the cause. I have gone ahead and ordered a seal for the tandom fuel pump to see if this will rectify the problem.
  2. Re: Engine oil in the diesel filter a3 1.9 tdi
    Nov 2006
    Achiltibuie
    Are you sure its engine oil, and not diesel infected with diesel bug? That makes the diesel black in coulour and could be confused with oil. If its that you can buy additive from most marine chandlers as this is a common problem in boats.
  1. Buying Oil, Some Basic Advice From Opie Oils
    By oilman in forum Chat - Anything with wheels
    Last Post: 13-10-2015, 11:16 AM
  2. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  3. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  4. Blown Turbo on AFN 1.9TDi engine?
    By justbretta in forum Archive posts
    Last Post: 18-12-2007, 04:56 PM
  5. Answers From The Oil Expert Part 2
    By oilman in forum Archive posts
    Last Post: 22-10-2007, 08:30 AM
