Thread: access to fuse board golf mk3
  1. access to fuse board golf mk3
    May 2008
    Cheshire UK
    This is for a 1997 2 litre Golf MK3 GTI. It's been to the leccy shop recently for work on its ignition stuff, and now there's a problem with the driver's side dipped headlamp. The passenger side dipped lamp works. The bulb for the driver's side works, but there's no power to the yellow wire at the headlamp. The earth passes a continuity check. The fuse (no. 2) is good. Looking for what can fail and what is unique to the driver's side, it's just the fuse and then the wiring from the fuse board. I suppose I have two questions.
    What route does the wiring take between fuse board and lamp?
    Can the fuse board be dropped down with the wiring attached so I can inspect it? I can see it's on a kind of hook support with a rotating detent to prevent it from bouncing off the hook, but how can it be moved for better access?
  2. Re: access to fuse board golf mk3
    Jan 2009
    towcester northants
    not being funny but have you tested it at the bulb or the back of the headlight?
    last one i had fault with was the connector to the light itself
  1. will mk3 gti alloys fit standard GOLF mk 3??
    By libbychalky in forum Golf MK3 - 1993 - 1999
    Last Post: 25-04-2008, 09:10 AM
  2. golf mk3 gti
    By husky jim in forum New Member Introductions
    Last Post: 21-12-2007, 07:25 PM
  3. Would A3 alloys fit my golf mk3 gti???
    By sgtpile in forum Golf MK3 - 1993 - 1999
    Last Post: 28-11-2007, 11:05 PM
  4. MK3 Golf Centre Box replacement
    By Alun in forum Golf MK3 - 1993 - 1999
    Last Post: 21-01-2007, 08:47 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
