Thread: 1.9tdi aux belt & tensioner
Results 1 to 10 of 15
  1. 1.9tdi aux belt & tensioner
    Jun 2008
    Hi guys need some help please. Have had this horrible noise when steering the car at low speeds. Noise was coming from power steering pump so changed that but still same noise there!Took it to garage today and they said its the auxiliary belt tensioner. Looked in haynes manual but theres nothing on how to change the tensioner so am after some advice please?thanks
  2. Re: 1.9tdi aux belt & tensioner
    If the alternator has a free wheel, it could be the problem
  3. Re: 1.9tdi aux belt & tensioner
    Jun 2008
    how doi tell if its got a free wheel?!!
  4. Re: 1.9tdi aux belt & tensioner
    Jan 2009
    towcester northants
    the freewheel pulley is 30mm deep and as a plastic cap on the front
  5. Re: 1.9tdi aux belt & tensioner
    To check it You will need to remove the poly-v-belt.Block the rotor in the alternator with something non conductive,(be careful,not to damage the rotor)you should be able to turn the pulley,in the one direction,without any resistance.
  6. Re: 1.9tdi aux belt & tensioner
    Southampton, UK.
    A failing alternator pulley/freewheel can cause a bit of a racket when stationary and also when turning the wheel, as it puts load on the aux belt. I believe you need a locking tool once you swing the tension roller out of the way with a wrench. Well, that's to get belt off. Maybe that will help to get you started.
    2003 VW Golf Est 1.9 TDI 130
    2006 Audi A3 2.0 TDI Sport 140
  7. Re: 1.9tdi aux belt & tensioner
    Jun 2008
    the guy at the garage said when he revved it up to 2000rpm the noise went away. Surely if it was alternator free wheel it would be constant? The noise stops when driving above 30mph. Can u buy these free wheels anywhere?
  8. Re: 1.9tdi aux belt & tensioner
    Southampton, UK.
    When revved there is enough force in the belt to turn the pulley. Mine only made a noise when the engine idled, as yours is doing. VW dealer should be able to order any part for you.
  9. Re: 1.9tdi aux belt & tensioner
    Jun 2008
    how much did it cost you to do the free wheel on your car?did you get it from vw?might try gsf to see if they do it!
  10. Re: 1.9tdi aux belt & tensioner
    Southampton, UK.
    Quote Originally Posted by martyn271985 View Post
    The alternator pulley started failing just as I was looking to book the car in for the cambelt change, so had the VW specialist do it at the same time. Got a feeling it was about £120 for the pulley and labour.
  1. Cam Belt damaged
    By awmw in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-12-2010, 08:54 PM
  2. 1Z alternator/aircon belt tensioner
    By john493 in forum Archive posts
    Last Post: 03-02-2008, 10:51 PM
  3. Noisy serpentine belt tensioner - PD 150
    By nath_mkiv_150pd in forum Golf MK4 - 1999 - 2004
    Last Post: 27-01-2008, 10:41 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. 1.9 Diesel Polo 1997 - Aux Belt tensioner
    By AbyssUK in forum Polo - Derby - Lupo - Fox
    Last Post: 06-06-2007, 10:50 AM
