Thread: tdi ecu light and fault code questions
  1. tdi ecu light and fault code questions
    My golf 110 tdi is down on power.
    My questions are:
    The ecu light is the glowplug light right?
    Shouldnt it come on when I unplug the maf? and the map sensor?
    Will i have fault codes even if I dont see the ecu light?
    Thanks Aaron
  2. Re: tdi ecu light and fault code questions
    Anyone know?
  3. Re: tdi ecu light and fault code questions
    May 2009
    daventry
    unless the ecu sees something out of range it wont show a light.
    my own 110bhp gt tdi didn't show a light but was down on power even with Vag Com at my disposal i had no codes to go at.
    ended up changing the air flow meter and the boost control valve at the back of the bulkhead.
    seemed to do the trick in my case at least. but it is a common fault.
    regards
    Dave
  4. Re: tdi ecu light and fault code questions
    Mar 2007
    coventry
    er glow plug light ?? ecu light ???
    you mean engine manage light ???
    any help is some better ???
    no matter how you try you always come back to what you first started
  5. Re: tdi ecu light and fault code questions
    Quote Originally Posted by golf tdi 02 View Post
    Yes I think so!! Diesels where so much simpler 15 years ago!! Yep engine management/glowplug light
  6. Re: tdi ecu light and fault code questions
    Quote Originally Posted by kicky1 View Post
    regards
    Dave
    Thanks for the reply,maybe the maf or bcv then? I will read the fault codes and if none show then I think I will be changing the above
  1. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Audi A4 2.5 TDI (04) Strange ECU fault Please Help!
    By 327521609 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-02-2008, 05:17 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. MK 3 Gti 16v Fault Code - ABS Problem
    By dravidham in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-01-2007, 08:10 PM
