Thread: Flashing PRNDS, 2004 GOLF GT TDI DSG 140 BHP. VAG-COM-DIAGNOSIS HELP ON FAULT CODE: 18012
  1. Flashing PRNDS, 2004 GOLF GT TDI DSG 140 BHP. VAG-COM-DIAGNOSIS HELP ON FAULT CODE: 18012
    Mar 2009
    Folks
    I would appreciate the help on the below read out of the VAG-COM diagnosis report.
    (Thank You Simon in Wiltshire for the VAG-COM availability, top guy very quick response)
    Fault Description: Flashing PRNDS, 2004 GOLF GT TDI DSG 140 BHP.
    Fault Code from VAG-COM:
    1 Fault Found:
    18012 - Internal Control Module: Output Driver IC Error
    P1604 - 000 - - - MIL ON
    Initially the fault was intermittent, i.e. would disappear randomly, short term workaround was to reset the fault codes or to disconnect the battery to reset the electrical circuits, however now the PRNDS lights flash continuously and although I am able to put the car into various gears the car simply doesn’t move in any direction.
    I am unable to locate fault code 18012 on the following website:
    http://wiki.ross-tech.com/index.php/Category:Fault_Codes
    I called Ross-Tech and they informed me the website is not updated with all fault codes and the best thing to do was to post on this forum for a quick response.
    Full output is pasted below.
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door,Rear Left -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 HJ HW: 028 101 225 3
    Component: R4 2,0L EDC 0000AG 7001
    Revision: 12345678 Serial number: VWZ7Z0D9700551
    Coding: 0050078
    Shop #: WSC 00722 210 06440
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 041 K HW: 02E 927 770 L
    Component: GSG DSG 0702
    Revision: 02904010 Serial number: 00000403290314
    Coding: 0000020
    Shop #: WSC 01279 785 00200
    1 Fault Found:
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023170
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No: 1K0 907 044 K
    Component: ClimatronicPQ35 061 0201
    Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
    Component: Bordnetz-SG 1.0 H30 0704
    Revision: 00030000 Serial number: 00000000637444
    Coding: E5890F0600041800001400001400000000
    Part No: 1K2 955 119 B
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00000
    Part No: 1K0 955 559 M
    Component: RegenLichtSens 005 0605
    Coding: 00217125
    Shop #: WSC 00000
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
    Component: 02 AIRBAG VW8 022 0600
    Revision: 05022000 Serial number: 0033JD0BCHLD
    Coding: 0012338
    Shop #: WSC 01268 785 00200
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 012 0030
    Coding: 0010012
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 960 LX
    Component: KOMBIINSTRUMENT VDD 3354
    Coding: 0003401
    Shop #: WSC 00430 210 63125
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 C HW: 1K0 907 951
    Component: Gateway H08 0080
    Revision: 08 Serial number: 260010431700CD
    Coding: 3F3F0B40070003
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO 3354
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
    Part No: 1K0 959 701 G
    Component: Tuersteuergeraet 09 0116
    Coding: 0000054
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 F
    Component: EPS_ZFLS Kl.3 1301
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    000 - -
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 T
    Component: 0W KSG 0560
    Coding: 81E802087F2D8505485FC61000
    Shop #: WSC 00000 785 00200
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Part No: 1K0 951 177
    Component: Innenraumueberw.004 0101
    1 Fault Found:
    01038 - Central Locking Thermal Protection
    000 - - - Intermittent
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
    Part No: 1K0 959 702 G
    Coding: 0000054
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 J
    Component: Radio BNO 0016
    Coding: 0040400
    Address 62: Door,Rear Left Labels: 1K0-959-703-GEN1.lbl
    Part No: 1K0 959 703 C
    Component: Tuersteuergeraet 06 0202
    Coding: 0000016
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
    Part No: 1K0 959 704 C
    Coding: 0000016
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    Revision: 00700000 Serial number:
  2. Re: Flashing PRNDS, 2004 GOLF GT TDI DSG 140 BHP. VAG-COM-DIAGNOSIS HELP ON FAULT CODE: 18012
    May 2007
    knee deep in clunge
    14 Post(s)
    mechatronics defective,fluid leakage onto the circuit board in the gearbox.Personally when i see this type of fault its a straight forward gearbox replacement.
    Best advise take to Vw and get them to check gff test plan for the fault code
  3. Re: Flashing PRNDS, 2004 GOLF GT TDI DSG 140 BHP. VAG-COM-DIAGNOSIS HELP ON FAULT CODE: 18012
    108 Post(s)
    1816 Post(s)
    Faulty Mechatronic unit, £1300 plus fitting or a new box at £3.5K plus fitting.
  4. Re: Flashing PRNDS, 2004 GOLF GT TDI DSG 140 BHP. VAG-COM-DIAGNOSIS HELP ON FAULT CODE: 18012
    Mar 2009
    hi thanks for the quick response guys. is there any independants that carry out this type of work or is the dealer my only option?
  5. Re: Flashing PRNDS, 2004 GOLF GT TDI DSG 140 BHP. VAG-COM-DIAGNOSIS HELP ON FAULT CODE: 18012
    108 Post(s)
    1816 Post(s)
    A VAG indi will be able to do the work IF they are experienced with DSG’s, the parts will cost the same but the labour will be less. Using genuine parts will still give you a two year dealer backed labour inclusive warranty.
  6. Re: Flashing PRNDS, 2004 GOLF GT TDI DSG 140 BHP. VAG-COM-DIAGNOSIS HELP ON FAULT CODE: 18012
    Mar 2009
    out of interest what would the value of this car be if sold with this known fault? i am considering all options repairing & keeping it, or even selling it in its current condition. i am open to sensible offers. i am hoping theres independents out there that maybe carry out the work themselves and either keep the car or sell on for a profit.. any feedback appreciated..
  7. Re: Flashing PRNDS, 2004 GOLF GT TDI DSG 140 BHP. VAG-COM-DIAGNOSIS HELP ON FAULT CODE: 18012
    Mar 2009
    folks i have confirmation from vw that the issue is with the mechatronic unit which requires replacement, i am considering selling the car in its current condition. im hoping there is an independant out there that can take the work on and make a reasonable profit, open to offers pls msg me.
  1. Golf TDI 90/110bhp engine query
    By william200mph in forum Golf MK3 - 1993 - 1999
    Last Post: 04-04-2008, 02:18 PM
  2. 2004 Audi A3 2.0 tdi (140 BHP)
    By james017 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-11-2007, 11:21 PM
  3. MKIV Golf Fault Code: P1609 "Crash shut-down activated"
    By laugharne in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2007, 08:05 PM
  4. First Facts on the Golf BlueMotion:
    Last Post: 13-08-2007, 07:08 PM
  5. Mk 4 2002 Golf tdi 150
    By Ketbmist in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-12-2006, 12:42 PM
