Thread: Brake Servo Hissing when engine turned off - MK3 Golf TD
  1. Smile Brake Servo Hissing when engine turned off - MK3 Golf TD
    Jul 2008
    Hi all
    I've noticed a slight hissing noise coming from my brake servo area on my mk3 golf td (1994 - M reg) engine code 'aaz' when the engine has stopped running,is this normal ??
    Thanks for reading.
  2. Re: Brake Servo Hissing when engine turned off - MK3 Golf TD
    May 2007
    South West
    No not normally, sounds like you have a leak from it, the servo creates a vacuum. I have this on my old Polo once, it was actually the pipe, so i replaced it.
    Does the car stall sometimes when applying the brakes?
  3. Re: Brake Servo Hissing when engine turned off - MK3 Golf TD
    1836 Post(s)
    It won’t affect the engines running as it is a TDI and the servo is operated by an engine driven vacuum pump, not manifold vacuum. As Saunders says, check the servo feed pipe for splits after the check valve and I have seen Golf 3 servo’s rust through due to the battering they receive from debris thrown at them by the pulley/belt over the years. A new servo pipe is £19 from VW, part number 1H2 612 041 S.
  4. Re: Brake Servo Hissing when engine turned off - MK3 Golf TD
    Jul 2008
    The car is the early TD version not a TDI.
    Is the pipe plastic or metal & are they easy to fit ?
    That is you don't need any special crimped jubilee clips at the ends ?
    Would this pipe be visible in the haynes manual or does anyone have any pics of where it may
    be situated in the car,as I wouldn't want to take off the wrong one.
    Also,just out of interest could this leak make the brake pedal feel a bit spongy when braking ??
    The cars had new fluid + discs + pads 1 month ago.
    Thanks for the quick responses..
  5. Re: Brake Servo Hissing when engine turned off - MK3 Golf TD
    Dec 2008
    Stockport
    Quote Originally Posted by tsam19 View Post
    ....Also,just out of interest could this leak make the brake pedal feel a bit spongy when braking ??
    The cars had new fluid + discs + pads 1 month ago...
    You've probably answered your own question there. New pads and discs will take a few hundred miles to bed in, so, so long as the work was done properly, that is most likely what you are experiencing.
  6. Re: Brake Servo Hissing when engine turned off - MK3 Golf TD
    1836 Post(s)
    Quite right, after all I own one; the I was a slip of the finger-your honour!
    Anyway, it makes bugger all difference. The pipe is plastic, pushes into the servo (a smear of washing up liquid helps) and onto the pump it will have a crimp clamp or worm drive clip. It is about 1-cm in diameter and runs from the vacuum pump on the front of the engine where the distributor would be on an 8 valve petrol engine and all around to the back of the engine bay along to the servo which is the 9 inch diameter big black round thing directly in front of the brake pedal with the mater cylinder mounted on front of it. A leak on this pipe will make the brakes feel less responsive.
  1. Brake Upgrade for mk3 golf 4 stud?
    By BugsyMalone666 in forum Golf MK3 - 1993 - 1999
    Last Post: 31-08-2007, 10:59 PM
  2. Golf mk3 knocking noise - Driveshafts, CVs or engine mounts?
    By p1nke in forum Golf MK3 - 1993 - 1999
    Last Post: 17-08-2007, 05:13 PM
  3. Mk3 Golf engine stalling
    By Kero in forum Golf MK3 - 1993 - 1999
    Last Post: 12-02-2007, 11:37 PM
  4. Mk3 Golf TDI Engine Judder
    By SteveC123 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-12-2006, 11:27 PM
