Thread: ABS and EPS lights stay on
Results 1 to 10 of 14
  1. ABS and EPS lights stay on
    Mar 2009
    I have a VW Passat 2.0 SE 2003 ,I have a abs and eps light staying on, I checked and i had no brake lights, so i changed the brake light switch and now have brake lights, after restarting the abs and eps light stayed off for a short while then came back on. but this time i still have brake lights, would the fault codes still remain if the fault is rectified? do the fault codes need to be cleared, and if so how can you clear them without the VAG-COM
  2. Re: ABS and EPS lights stay on
    Norfolk
    97
    Yes fault codes remain until you clear them with vag-com or similar. You need to fix the fault first or they will come straight back.
  3. Thanks mercer2773 thanked for this post
  4. The Following User Says Thank You to martin1810 For This Useful Post:
    mercer2773 (21-03-2009)
  5. Re: ABS and EPS lights stay on
    Mar 2009
    Thanks Martin1810 I put the new brake switch on but i had no brake lights until i depressed the brake pedal down fully. when they should come on when you press the pedal lightly. I pulled the brake pedal towards me because maybe the the sprung pin was not making the right contact with the pedal ,but pulled it to much and broke the brake switch I had no choice but to put back on the old switch. now the brake lights come on when i press the pedal lightly great also the abs and eps light has gone off. seems strange it now works with the old unit. is there a nack of putting on the new switch? do you need to do anything to the switch before you install it, i did push down the pedal when i installed the new one !! any idea's ?
  6. Re: ABS and EPS lights stay on
    33
    Quote Originally Posted by mercer2773 View Post
    The fault will come back, when you fit the next switch, do not press the pedal, push the switch into the bracket and it will ratchet the centre pin to the correct adjustment when you twist it into the bayonet fitting the centre pin locks at that setting.
  7. Thanks mercer2773 thanked for this post
  8. The Following User Says Thank You to caldirun For This Useful Post:
    mercer2773 (22-03-2009)
  9. Re: ABS and EPS lights stay on
    Mar 2009
    Quote Originally Posted by caldirun View Post
    Thanks Caldirun if I need to change the brake light switch again i will follow your advice
  10. Re: ABS and EPS lights stay on
    May 2008
    0
    I fitted a new switch this morning and all the assistance on the forum has helped. However my problem still persists - no brake lights.
    I'm wondering if i damaged the switvch before installing it. I did push the plunger several times to get a feel for the action of the switch. Have I upset any setting on the switch itself?
    I've tried several position by adjusting the amount the switch is screwd into the mount and thought I had it perfect - but no brake lights!
    Is the answer to but another switch? Current one from german and swedish.
  11. Re: ABS and EPS lights stay on
    33
    Have you checked the lamps and fuse?
    The switch is a bayonet fit, how can you screw it in, its push in and twist
  12. Re: ABS and EPS lights stay on
    197
    Quote Originally Posted by wheelywonderful View Post
    What year is your car, two pin or four pin switch, which GSF part number, what colour was the switch and did you fit it pedal down or up?
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
    www.helpforheroes.org.uk
    Keep XH558 in the air
    www.vulcantothesky.org
  13. Re: ABS and EPS lights stay on
    May 2008
    0
    Thanks for coming back guys.
    My car is x reg 1.8T estate.
    Central brake lamp works so I'm puzzled - thought it was on the same circuit. Fuse looks ok.
    Was sold the wrong lamps but the ones in place look ok. Think that must be my next thing to check - cheap and easy.
    GSF number of part which ius 4 prong version - 931VGO2360. Installed with pedal depressed but it was tricky - I needed an extra pair of hands and may have inadvertantly allowed the pushrod of the switch to be depressed.
    HELP - this is so bxxxxx annoying.
  14. Re: ABS and EPS lights stay on
    33
    Fitting with the pedal depressed was the problem, the switch auto adjusts as you press it into the bracket and the plunger hits the pedal, as you twist it to lock the plunger is set at this distance. With the pedal depressed the plunger would lock at the fully out position and when the pedal came up it would wreck the switch.
  15. Thanks Crasher thanked for this post
  16. The Following User Says Thank You to caldirun For This Useful Post:
    Crasher (05-06-2011)
  1. Question Sharan dashboard lights stay on
    By PippyM in forum Touran - Sharan - Caravelle
    Last Post: 07-01-2009, 07:20 PM
  2. A4 Reversing lights stay on!
    By chekers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2008, 08:52 PM
  3. Interior Lights Stay on in Audi A6 Avant
    By darkskies in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-10-2007, 04:08 PM
  4. Help! Bora Automatic- reverse lights stay on when in drive!
    By biscuitclaire in forum Bora - 1998 - 2005
    Last Post: 01-08-2007, 08:07 PM
  5. Courtesy Lights Stay on?
    By Ruby in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-07-2007, 12:23 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
VW Audi Forum is an AUTHORISED retailer for the Surf City Garage range of car care products
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
