Thread: OBD P2102 Fault Code
  1. OBD P2102 Fault Code
    Mar 2009
    Hello Boys and Girls
    I've got an Audi 2.0 TDi - 55 reg. (2005 - 2006)
    I've got a P2102 Fault when i plug into the OBD port.
    It does reset, but comes back up after a few mins of the engine running.
    I've searched on the internet and it seems to be 'Throttle Control Motor'.
    Can anyone advise me what could cause the fault and if it is DIY repairable.
    Many Thanks
    Andy
  2. Re: OBD P2102 Fault Code
    Norfolk
    A vag-com read might give you a more accurate pointer. If the car is working it suggests that the throttle needs replacing because the ecu is getting a signal it doesn't like. e.g resitance or votage out of spec. That suggests that the throttle is struggling to open and close properly (needs cleaning) or throttle motor is dying.
  1. VAGCOM Fault Code 00588 - Airbag fault
    By headache56 in forum VCDS - General Questions
    Last Post: 31-01-2009, 01:05 PM
  2. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    Last Post: 16-01-2009, 06:05 PM
  3. ABS Fault, have fault code readout....
    By nemeth782 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-08-2008, 12:15 PM
  4. Help with fault code
    By xp800 in forum VCDS - General Questions
    Last Post: 29-04-2008, 09:11 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
