Thread: ABS warning light & flashing brake light
  1. ABS warning light & flashing brake light
    Feb 2009
    Hi, I have a VW sharan 1.9TDI 130 2004. The ABS warning light came on followed closely by the Brake light flashing, then the speedo stopped working then the indicators (hazard lights work ok). The Fuel guage then started doing strange things- needle would float back and forward between 1/4 tank and empty and the refuel warning light kept coming on. been to the garage fluid levels seem ok so they are suggesting new dash! Any other ideas before I spend £500?
  2. Re: ABS warning light & flashing brake light
    Hi, I have the same problem with my 2001 Sharan, did you get this fixed and was it a replacement dash?
  3. Re: ABS warning light & flashing brake light
    Quote Originally Posted by mrbiondi View Post
    Did you ever get this fixed? I have the exact same problem.
  4. Re: ABS warning light & flashing brake light
    Dec 2007
    did either of you get this problem fixed as i have exactly the same problem ??
  5. Re: ABS warning light & flashing brake light
    Quote Originally Posted by wubnutm3 View Post
    Yes, i did.
    For me it turned out to be an expensive excercise which had the complete car stripped down.. The problem was that one of the electric plugs holding the wires into the back of the speedo worked loose and started to short out.
    The plug that connects the speedo/drivers display unit had worked loose and started to short out and melt. finding the issue was what cost the money but take a look at the main drivers display unit to ensure the plug isnt causing the short, you might need to take the dash apart.
    Hope that helps and good luck
  1. Flashing colant light and no brake warning light
    By cookie7354 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-09-2008, 11:24 PM
  2. ABS and brake warning light flashing
    By Leon Fletcher in forum VCDS - General Questions
    Last Post: 31-07-2008, 01:27 PM
  3. A6 Yellow ABS Light And Flashing Red Brake Light
    By mikekirchner in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-01-2008, 08:15 PM
  4. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 09:26 PM
  5. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-10-2007, 06:02 PM
