Thread: VW Transporter T5 Wipers
Results 1 to 10 of 11
  1. VW Transporter T5 Wipers
    Fraserburgh Aberdeenshire
    Can anyone tell me where the wiper relay is located in a 2004 VW Transporter T5?
  2. Re: VW Transporter T5 Wipers
    Oct 2007
    Hi It doesn't have one.They are powered through the onboard supply control unit.
  3. Re: VW Transporter T5 Wipers
    Sorry, no idea what I did there but I seemed to start a new thread.
    Can you tell me, and do you know of any common problems that could have caused my wipers to stop working? I have checked the fuses and the linkages are ok, just no motion at the motor.
  4. Re: VW Transporter T5 Wipers
    Oct 2007
    No common problems.The easiest way to eliminate the motor is to check if you have or have not a power supply to the motor,You will need to take from there as it could be the switch or the onboard supply unit,if all fuses are ok.Check the earth wire on the motor.
  5. Re: VW Transporter T5 Wipers
    Thanks for that.
    Is there only the one fuse box in the van. I have been looking in the one to the rhs of the glove box.
  6. Re: VW Transporter T5 Wipers
    Oct 2007
    In reality you have 3 fuse boxes SA engine bay;SB and SC in the centre consol of the dash.There are 2 fuses connected to the wiper, fuse 10 and 32 in the upper fuse box(SB)
  7. Re: VW Transporter T5 Wipers
    Thanks for the advise. I have checked the motor and the earth is fine but there is no power up to the motor. I have double and treble checked the fuses and they are fine. Could it be the power supply unit? If so where would I find it?
  8. Re: VW Transporter T5 Wipers
    Oct 2007
    It is a 50x50 chance,either the onboard supply unit or the switch.There is a fault finding programme to find out,but you will need to visit a VAG workshop.
  9. Re: VW Transporter T5 Wipers
    Thanks for the help,
    Where can I find the power supply?
  10. Re: VW Transporter T5 Wipers
    Feb 2009
    I have an as new wiper switch if it turns out to be that.
  1. Front slow wipers, faulty wiper motor, wipers park intermittently
    By guddo1969 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-12-2008, 09:51 AM
  2. Wipers for A6
    By barrheadbear in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-12-2008, 08:27 PM
  3. Wipers
    By emm_11 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2008, 10:32 PM
  4. wipers
    By warrick in forum A2
    Last Post: 10-11-2007, 08:16 PM
  5. wipers
    By wednesday13 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-03-2007, 10:38 PM
