Thread: Anyone changed a rear wheel bearing on a Polo Gti?...
  1. Anyone changed a rear wheel bearing on a Polo Gti?...
    Jan 2009
    One of my rear wheel bearings is making a real din now on my 2001 polo GTi - anyone changed one of these themselves? Easy job, or fairly straightforward?
    Also anyone got any idea what the wheel bearings cost for these? (its discs on the rear on the gti)
    cheers
  2. Re: Anyone changed a rear wheel bearing on a Polo Gti?...
    1840 Post(s)
    The bearing is a complete hub on a 6N2, the part number is 6X0 598 477 for the VW kit which is rather expensive at £78 but will be available elsewhere for much less, say from GSF. The hub nut requires a 12 sided socket (30-mm off the top of my head) and then the hub just slides off, after removing the caliper and disc of course. The nut must be torqued up to 175Nm and a new nut MUST be used.
  3. Re: Anyone changed a rear wheel bearing on a Polo Gti?...
    Jan 2009
    cheers crasher
    I've been quoted £50+vat from the local specialist, so I think I'll take him up on that and get it done while I get the pedal box changed out If VW are charging £80 odd then I can't see GSF being massively less than £40 so £50+vat fitted sounds like a fair price.
  1. A4 wheel bearing changed... now the ABS light is on
    By cliff2710 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-09-2009, 01:16 PM
  2. Rear wheel bearing
    By Ericthered in forum Golf MK4 - 1999 - 2004
    Last Post: 10-12-2008, 10:30 PM
  3. Rear wheel bearing replacement
    By Panzerdriver in forum Golf MK4 - 1999 - 2004
    Last Post: 29-07-2008, 05:33 PM
  4. Changing rear wheel bearing
    By GarJE in forum Golf MK5 - 2004 - 2009
    Last Post: 12-07-2008, 06:35 PM
  5. The rear wheel bearing wanted
    By Laurence Tsai in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-02-2007, 03:25 PM
