Thread: Tyre pressures
  1. Tyre pressures
    Feb 2007
    Hi all.
    Thanks for all the help in the last couple of weeks, i went to look at a few before i went way over budget and brought myself a 2001 51 plate sport model. I am well pleased with it.
    I had a look through the manual for tyre pressures and it told me to go to the filler flap, which it did. However it worked in bars and not PSI.
    So my question is;
    What PSI should i be running on my 16inch rims.
    I did do a search but couldn't find anything!
    Thanks,
    Fozzie!
    Jun 2006
    UK, Mids
    15psi = 1bar
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by snapdragon View Post
    15psi = 1bar
    Actually, to be pedantic: 14.7psi = 1 bar
    Oct 2005
    Most, if not all, service station air lines have both PSI and BAR units.
    You're looking to put in around 32 psi for normal driving and more for high speed motorways.
    Nov 2006
    Swampyland, UK
    Yebut . . . most service station air lines are woefully out of calibration, and give inaccurate readings. Furthermore, tyre pressures should be checked whe the tyres are cold.
    Every motorist should carry their own PCL type tyre pressure gauge, in their car or in their garage.
    Now that is not doing any favours, Sam. You really should not guess tyre pressures. If the sticker is missing, get the local VW dealer to order another one - about £2.
    Oct 2005
    Quote Originally Posted by Teutonic_Tamer View Post
    Totally agree, but, not every motorist does.
    Very true, but I'm not guessing, that's the reading from the lid/door of my 2001 Passat saloon albeit in bar.
    EDIT: Just had a proper look at the filler flap
    Two people = 2,0 front and 1,9 rear
    Fully laden = 2,2 front and 2,8 rear
    This is for stock 15" wheels. People say and 2psi for every inch you increase from stock (in my case 15") so adding (or using) 16" wheels puts the pressures up to;
    Two people = 31/29
    Fully laden = 34/44
    Which seems excessive to me.
    I ran stock 15"s at 34/34 for three years with no abnormal effects/tyre patterns. YMMV /EDIT
    A quick search of the forums on www.passatworld.com using "tire pressure" (blasted Americans) gets you oodles of results and statistical findings
    Jul 2006
    Farnham, Surrey
    Mine's 2.3 bar all round for normal load & 2.5/2.8 for loaded up. '97 1.8T saloon with 195X65X15" tyres.
    I guess that means they're all different then?
    Hey - I wonder if the 14.7psi thing has anything to do with the perfect fuel/air mix of 14.7:1 ?
  1. A4 Tyre Pressures!
    By Desdesigner in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-04-2007, 09:25 AM
  2. A6 tyre pressures
    By buster in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-04-2007, 07:32 PM
  3. TT Tyre Pressures
    By richml in forum TT - 8N Forum - 1998 - 2006
    Last Post: 18-03-2007, 08:07 AM
  4. tyre noise
    By mlowdon in forum Chat - Completely Off Topic
    Last Post: 07-03-2007, 07:28 PM
  5. Tyre Sizes
    By martinj in forum Passat - Archive Topics
    Last Post: 26-06-2006, 10:36 AM
