Thread: VW Passat TDI Brake fault
Results 1 to 10 of 14
  1. Angry VW Passat TDI Brake fault
    Jan 2009
    Hi, I am new to this site and would like some help please! Went out in my car at 6.30 am today ( very cold minus 6 degrees) drove approx 2 miles and when i braked at a junction the brake pedal was solid & no brakes ! I had braked earlier in this journey & all seemed ok. I drove on for approx 50 mtrs and tried them again - were ok. Drove on ( carefully!) for another 2 miles , same thing at next junction - then were ok again, end of journey was at 5.5 miles & same thing again when stopping to park, backed up - drove forward & braked again - all ok . Did journey home at lunchtime & all seemed ok
    Any ideas ?
  2. Re: VW Passat TDI Brake fault
    Tyldesley, Manchester, UK
    It sounds like a servo problem to me. I take it when they went hard they still stopped you, but required more brake pedal force?
    One German, Two Italian.
  3. Re: VW Passat TDI Brake fault
    Jan 2009
    No they didnt stop me - pedal was solid & I couldnt depress it at all ( that might be coz i am a girl though!!)
    I have a fab chap that services it etc - will call him tmorrow!!
    just wanted ideas from others as was scarey
  4. Re: VW Passat TDI Brake fault
    Stafford, Midlands
    sounds like the problem ive seen on here before where water gets into the brake servo ad when it gets cold enough it'll freeze, hope it is something as simple as this and not a total failure of the master cylinder?
    Subaru broken, sold, Silver Seat Leon Cupra 180 '02' no cupra badge?
  5. Re: VW Passat TDI Brake fault
    Jan 2009
    Having surfed round the forum, the more i read - the more it sounds like water in the servo - as about 3 weeks before christmas I had problems with warning lights for various things coming on all over the dash /wet footwells too - i spoke to my "car man" who said sounded like water in the area under battery - common fault he said - i had all that out & there was at least an inch of water in there as the the drain holes blocked with muck. cleaned all that out & had computer thingy reset at the garage . All ok until this with the brakes - its due service & MOT during this month - so will get it booked in asap & get all looked at . Many thanks to those who helpd me !
  6. Re: VW Passat TDI Brake fault
    Stafford, Midlands
    you may have to ask nicely to get them to take the battery out to cure water problem, not the simplest of jobs, i suggest a pair of false lashes and a low cut top, works for me
  7. Re: VW Passat TDI Brake fault
    Mar 2009
    Quote Originally Posted by passatgirly View Post
    Any ideas ?
    My vw passat is also giving me the same problem. Can you offer any help from your experiences. Many thanks.
  8. Re: VW Passat TDI Brake fault
    Mar 2009
    Any ideas ?
    Did you ever find out what the problem was? Thanks
  9. Re: VW Passat TDI Brake fault
    Quote Originally Posted by psingh View Post
    I suspect water in the plenum as it is a common fault.
  10. Re: VW Passat TDI Brake fault
    Jul 2008
    Quote Originally Posted by MalcQV View Post
    Seconded.
  1. 03 plate Diesel passat- stop brake fault
    By bigmarkl in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-05-2009, 02:34 AM
  2. Brake warning light fault Passat
    By mikeybarvas in forum Passat - Archive Topics
    Last Post: 19-12-2007, 10:01 AM
  3. New Passat - Parking brake system fault warning - Advice please
    By jarnelljones in forum Passat - Archive Topics
    Last Post: 05-09-2007, 07:41 PM
  4. 00 Passat- brake fault, abs, traction control lights on
    By rallen043 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-09-2007, 10:53 PM
  5. Passat 130tdi brake fault!
    By mike1 in forum Passat - Archive Topics
    Last Post: 19-06-2006, 10:15 PM
