Thread: Passat Towbar Electrics
Results 1 to 8 of 8
  1. Passat Towbar Electrics
    Oct 2006
    I have a 2004 Passat Saloon and have a Bosal towbar to fit.
    Another site has mentioned a CAN-Bus circuitry adapter for installing the electrics to the towbar hook up point. I understand this attaches to the rear light cluster.
    At about £50 is this worth the cash or should I simply spur off existing wiring?
    Help please.
    DC
    7 Post(s)
    As a 2004 it should be a B5.5 ?
    If so, you shouldn't need the can-bus adaptor, a B6 would.
    Oct 2006
    Yes, it is a B5.5
    Can you confirm the best way to add the electrics and where from?
    DC
    7 Post(s)
    Mine are spliced into the cables on the back of the rear clusters.
    Use scotch-locks or for a proper job, solder.
    Caterham, Surrey, UK
    For about £50~£60 you can get the 'proper' VW set from your local parts dept. (or try VAG Parts). I believe that jobs plugs into to the rear light cluster and saves you splicing any wires... May even make the dash light work if you;re lucky
    Good luck
    Andy
    Oct 2006
    Thanks for that.
    Which dash light are you referring to that 'might' work?
    DC
    Quote Originally Posted by dickturpin View Post
    Thanks for that.
    DC
    Between the Cruise Control and Airbag warning lights on the rev counter dial is a trailer turn signal warning light. This is effectively the repeater to show you that the trailer indicators are working (it flashes when you indicate if they are working)
    Good luck...
    Andy
    Oct 2006
    Thanks Andy
    DC
  1. A6 Avant towbar fitting
    By SimonP in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 10-12-2010, 08:21 AM
  2. A4 Avant Towbar Electrics
    By rwavant in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 13-10-2007, 12:06 AM
  3. Touran 1.9D 105 Towbar Electrics
    By charlietouran in forum Touran - Sharan - Caravelle
    Last Post: 05-03-2007, 02:07 PM
  4. FS: Passat B5.5 towbar (detachable, estate)
    By Carps in forum Passat - Archive Topics
    Last Post: 02-02-2007, 08:39 PM
  5. Towbar electric on 03 Passat
    By Stu&Pet in forum Passat - Archive Topics
    Last Post: 06-02-2006, 01:09 PM
