Thread: quantity adjuster
  1. quantity adjuster
    Dec 2008
    hi all, i hope someone can point me in the right direction please,
    i own a 98 passat 1.9tdis
    unsteady idling and spluterring at low rpm on acceleration,
    hooked her up to vag -com
    got following code: 01268 - quantity adjuster (n146) 35-10 ---intermittent
    does this mean i need to replace the fuel pump?
    thanks....
  2. Re: quantity adjuster
    london/ UK
    Quote Originally Posted by deezilbob View Post
    thanks....
    More likely you will need to reccondition the fuel pump...I would check the pump's conectors for signs of corosion first... There are write-up's on the net about people fixing said pumps(quantity adjusters, fuel temp. sensor, etc.) by oppening the domed black box on top of the pump, however i would not touch that as they are prone to leak and the quantity adjuster needs fitting in exactly the same position(use tipex marks) or the pump will not work well at all ! U will need an special socket as well but you can take it off by hammering over a suitable round, multipoint socket. Halfords do cheap 6-7mm long deep sockets wich work a treat and if you dammage it, yopu can throw the socket away !
  3. Re: quantity adjuster
    Dec 2008
    thanks adam , maybe ill just need to buy a pump then,
    probally best to get it fitted at a specialist?
    ill presume the pumps are expensive....
    im in ayrshire if anybody knows a decent garage.. thanks
  1. new cam chain adjuster in 1.8t hard?
    By ssray in forum Chat - Completely Off Topic
    Last Post: 30-06-2009, 09:46 PM
  2. Timing chain adjuster - 2.7T V6
    By mfinsf04 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-11-2008, 09:50 AM
  3. seat adjuster
    By shuggie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-07-2008, 08:30 AM
  4. Oil quantity AKL 1.6 engine -
    By w.pinnell in forum Leon
    Last Post: 05-05-2008, 11:06 AM
  5. Repair to air vent adjuster
    By braggit13 in forum Archive posts
    Last Post: 02-11-2007, 11:31 PM
