Thread: Intermittent windscreen vent problem
  1. Intermittent windscreen vent problem
    Dec 2008
    I have an Audi 1.9 TDi SE
    I seem to have an intermittent problem with my Windscreen AC vent.
    Every now and then the vent doesn't blow any air out. It's making all the right noises but no air escapes. It seems as though it's blocked.
    Any (DIY) help would be appreciated.
    Ste
  2. Re: Intermittent windscreen vent problem
    Southern County Softy
    20 Post(s)
    A4 2.5 tdi QS (mapped)
  3. Re: Intermittent windscreen vent problem
    Nov 2006
    scotland
    My 2002 a4 had same problem this week. I took motor out & opened flap manually as a quick fix for now. It's not blocked, the motor isn't opening the flap. I think my motor is ok, it just isn't getting a live feed so it may be a switch problem
  4. Re: Intermittent windscreen vent problem
    Sep 2007
    Windsor
    Quote Originally Posted by jak View Post
    More likely to be a problem with the pot in the motor unit. You can check the operation of the motor by applying 12 V across pins 5 and 6. To eliminate a wiring or control unit problem, plug the motor unit in place of one of the motors that does work ok.
  5. Re: Intermittent windscreen vent problem
    Dec 2008
    Got the same problem with my 03 A4 2.5tdi q.
    Gonna try this first.....
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=54572
  6. Re: Intermittent windscreen vent problem
    Nov 2006
    scotland
    Hi Xenon
    I'd already tried the motor with another motors wiring plug & it was ok , that's why i suspect the switch or wiring
    john
  7. Re: Intermittent windscreen vent problem
    Sep 2007
    Windsor
    Hi Xenon
    john
    Sounds like it could be a control unit problem. I would advise to get the car scanned for fault codes - might throw up the problem there.
  1. Windscreen Wiper Problem
    By Bon in forum Golf MK3 - 1993 - 1999
    Last Post: 26-04-2008, 08:35 PM
  2. Air Vent Problem
    By grahamcoutts in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-03-2008, 11:02 PM
  3. Intermittent windscreen wiper problems
    By madcarew in forum Archive posts
    Last Post: 24-01-2008, 03:29 PM
  4. Dashboard Windscreen vent
    By dickturpin in forum Passat - Archive Topics
    Last Post: 02-03-2007, 08:43 PM
  5. Glovebox latch and windscreen vent
    Last Post: 25-01-2007, 08:06 PM
