Thread: Below average MPG?
  1. Question Below average MPG?
    Dec 2008
    I have a 2001 A6 1.8T that has done 107,000 miles. It has been regularly serviced but not in the last year. Although I have had the oil pump replaced. I have been checking my average MPG and it is around 22 to24 mpg. Is this normal as i have never realy noticed what it has been doing since I got it. I plan to take out the maf and replace the air filter. Will this improve MPG? I tend to drive carefully but only do short journeys of about 4 miles to work.
    Any advice on how I could improve the fuel consumption without spending a fortune would be gratefully received.
    Phill
  2. Re: Below average MPG?
    I'd say that's about right for short 4 mile trips. It's not really warming up properly. Plus at this time of year you'll drop a couple anyway.
    I'm driving the 2.8 quattro and town driving gives low mpg. A mixture of town, short M-way and mainly back roads returns about 29 - 30 mpg for me at this time of year. 32 - 34 in summer.
    Trips on the M-way deliver 37+ easily
  3. Re: Below average MPG?
    22 is too low either you have the ECU element of the temp sensor faulty or the MAF is failing and it is over fuelling slightly Locally I never get less than 30 and on a sensible run 37 and a long motorway run 300 miles plus just over 40, ( 40.2 mpg 330 miles ) even I was implessed with that, Shell fuel and Edge 5/30 oil. Less with Tesco fuel ( 38.7) same run. Regards Peter
  4. Re: Below average MPG?
    Dec 2008
    cheers lads. I plan to get the MAF out and give it a clean, I have had a look on other posts and have guessed that the MAF is behind the air filter? I am not sure though where the ECU is and what it does. Any tips on checking my ECU for faults would really help me?????
    Phil
  5. Re: Below average MPG?
    4 mile trips in winter through town I thought would return pretty poor mpg?......
    Yes the MAF is the part connected just after the air filter.
    And I also experience lower mpg if using Tesco fuel. Their 99 octane is definitely not a geniune 99 octane that's for sure. Shell's Super Unleaded gives very good results. Works out cheaper too.
  1. Average MPG on DIS
    By kenhodgson in forum VCDS - General Questions
    Last Post: 11-04-2009, 10:40 AM
  2. bigger than average bill !
    By snj376 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-11-2008, 01:23 PM
  3. the average man.
    By STEWY L in forum Chat - Completely Off Topic
    Last Post: 30-03-2008, 12:55 AM
  4. A4 3.0 Quattro - What's your average MPG please?
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2008, 07:20 PM
  5. whats your average mpg?
    By mysterygti in forum Golf MK4 - 1999 - 2004
    Last Post: 21-01-2008, 07:42 PM
