Thread: Vibration, A4 Avant 3.0Tdi quattro tip.
  1. Vibration, A4 Avant 3.0Tdi quattro tip.
    Dec 2008
    I recently bought this almost perfect 2005 Xtra high miler for a song. It has little SH, but I have taken this chance before on two previous occasions (100 avant & 1.9Tdi avant). I took it immediately to my usual independent for a thorough going over and all it needed was a fuel filter. I pointed out a drive through vibration @ 50-60, and they gave me it back saying "fixed with wheel balance". It's not, and now it's between 40 and 50 mph - commuting speed, annoyingly. This and some other stuff has made me lose confidence in the independent with whom I have been doing business for 8 years or so.
    Anyone any ideas before I take it to Kwikfit for their chance? Anyone know a truly honest reliable intelligent garage north of Perth, south of Inverness? This car also has the S-line suspension and very low profiles which are practically new.
    Pity, because otherwise it's a joy, and when you buy cheap luxury you have to be prepared to take good care, but that doesn't stretch to the potted palms at the local rip-off Audi franchise in Oilcity.
    rmaxibiza
  2. Re: Vibration, A4 Avant 3.0Tdi quattro tip.
    Chester-le-Street, United Kingdom
    if it was 50-60 before the rebalance,and is now at 40-50,then i would say try another
    tyre place.
    i find the small guys down here are better than the "supermarket" types.
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Vibration, A4 Avant 3.0Tdi quattro tip.
    Angus, Scotland
    I agree, if a re-balance has shifted the speed range then its the balance at fault.
    Best place for blalance I have used is the on in Dundee, on the road between Broughty Ferry and the Tay Bridge. Think its Hi-Q, on the left heading from B Ferry to the bridge just next to the 30 mph sign IIRC. You cant miss it
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  4. Re: Vibration, A4 Avant 3.0Tdi quattro tip.
    Aug 2008
    Somerset
    Might be worth checking if the tyres have any significant radial runout (ie aren't properly round). I had trouble tracking down a persistent vibration (at slightly higher speeds than yours though) despite careful rebalancing, and it turned out to be a single tyre with a significant 'hop' in it. Replaced the tyre... bingo! No vibration.
    Not all balancing places can check for runout. Worth asking.
  1. 2.0TDi 170 S-Line Quattro - Understeer/Vibration at low speed & full lock
    By wizbongre in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-02-2009, 03:55 PM
  2. Question Quattro Vibration
    By steveb5avant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-11-2008, 11:54 PM
  3. A4 Avant 1.8t Vibration
    By FT08 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-03-2008, 01:08 PM
  4. Tyre Choice A6 3.0TDI Quattro Avant
    By daweller in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 02-09-2007, 11:32 PM
  5. A4 Avant vibration
    By ian5509 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-05-2007, 11:06 AM
