Re: Help! VW T5 power loss. Turbo, bad fuel? –
26-10-2009,01:06 PM
Originally Posted by
paul b
Symptoms are loss of power, lots of black smoke under load and reduced fuel economy.
Hi Paul,
Were there any codes coming up on VAG-COM? Your description above *exactly* matches what happened to my last A6 when the EGR broke. The flap had parted company with the spindle inside the EGR valve, and because the spindle was still moving correctly, no faults were flagged when the car was scanned. Dropping the clutch and pumping the throttle would clear the problem at first (presumably the flap was being moved enough by doing this to allow normal running), but it very quickly got to the point where the car was undrivable. The RAC recovery man had to try several times to get enough power to reverse the car out of a parking space on a flat surface before he could winch it onto his flatbed, and the smoke from the exhausts was astounding!
The Audi dealer it got recovered to replaced the ECU, AMM, Fuel Pump, fuel filter, fuel lines, and removed and cleaned out the fuel tank before they got round to looking at the EGR after two weeks. During this work they "forgot" to enable cruise control function in the new ECU, and introduced three separate fuel leaks. It's obviously not fair to mention the garage concerned, other than to say that their name rhymes with Plough Saudi.
Hope you managed to track the problem down and fix it!
MF.
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
