Thread: VW Golf MK4 1998. Uneven tickover.
Results 1 to 10 of 16
  1. VW Golf MK4 1998. Uneven tickover.
    Mar 2008
    1
    My wife has a1998 Golf 1.6 SE. For at least 6 months now, the idle speed sometimes rises to about 1400rpm then drops down again. It can happen anytime, when hot or cold. Other times it fluctuates between 800 and 1400rpm constantly. The problem is annoyingly intermittent though.
    It has been serviced twice now since the problem first started, at two different garages. Both garages plugged the car into the computer system, but it showed no faults when there obviously is. Both times at both garages I was present when it was checked on the computer, so I know it has been done.
    Does any of you good people have any idea what the problem could be, or is it just a case of throwing money at it replacing different parts until the problem is found?
    Thanks in advance, Stuart.
  2. Re: VW Golf MK4 1998. Uneven tickover.
    Oop a gum tree
    198
    Quote Originally Posted by stupotads View Post
    Sounds like a classic case of a gunked up throttle body.
    Do a search on here for loads of info.
    The throttle body needs to be cleaned with carb cleaner and then should be electronically aligned / calibrated. A easy DIY job for the cleaning and if you look in the vagcom subforum there should be someone who could help you with the alignment.
  3. Re: VW Golf MK4 1998. Uneven tickover.
    Mar 2008
    1
    Cheers BigCol, appreciate the info.
  4. Re: VW Golf MK4 1998. Uneven tickover.
    Mar 2008
    1
  5. Re: VW Golf MK4 1998. Uneven tickover.
    Mar 2008
    1
    Went back to the garage today and had the throttle body removed and checked. It was spottless, but cleaned again anyway. All other things were checked that could possibly cause the throttle problem, and reset the throttle position again. The fault codes were all reset again too. I then took the car aout for about 7 miles for a test, but without luck, the problem is still there. It was then plugged back into the computer, but strangely, it was showing 'no faults found'.
    It was then suggested that a new throttle body was fitted. I would be happy to do this if it was a guaranteed fix, but of course it isn't. I was quoted 194 + vat for the part, the part number is 06A 133 ( I think ). Does anybody know if that is a good price, or suggest anywhere I might get it cheaper?
    Thanks again in advance!
    Stuart.
  6. Re: VW Golf MK4 1998. Uneven tickover.
    Southern County Softy
    53
    No air leaks ?
    A4 2.5 tdi QS (mapped)
  7. Re: VW Golf MK4 1998. Uneven tickover.
    Mar 2008
    1
    No. No leaks. Spent about two hours on it.
  8. Re: VW Golf MK4 1998. Uneven tickover.
    53
    Stu, try Vagparts or GSF for a price....I think we get a discount working where we do !
    GSF list it at 174+vat= 204
    GSF part No....18777
  9. Re: VW Golf MK4 1998. Uneven tickover.
    Mar 2008
    1
    Here we go again. I replaced the Throttle Body today with a genuine new part. Started her up, but exactly the same symptoms. One thing not noticed before, is when you hold the throttle open by the cable with your hand, it seems to kick back and drops the rev's down. Same when you hold the pedal down at about 2000 rpm, you can feel the pedal move on its own and the rev's will drop down to about 1500rpm, and then shoot back up again.
    Also,I did find a pin ***** size hole in a section of the pipe between the Mass Flow Meter, and the Throttle Body. Could this tiny hole really cause this much of a problem?
    After running a check on the laptop, a fault comes up as : 00533 - Idle Speed Regulation: Adaptation Limit (Add) Exceeded. Again, could this be down to this tiny hole?
    All responses much appreciated.
  10. Re: VW Golf MK4 1998. Uneven tickover.
    Nov 2008
    0
    this is exactly whats wrong with mine
    pedal kicks back and revs wont drop
    i cant afford to spend 200 and it still not work
    would like to know the outcome of this
    can you let me know?
    cheers
  1. Please Help mk iv golf gti tickover issue
    By d007p in forum Golf MK4 - 1999 - 2004
    Last Post: 10-10-2008, 06:52 PM
  2. Golf mk3 1.8 driver judder misfire on tickover
    By sumomus_01 in forum Golf MK3 - 1993 - 1999
    Last Post: 19-02-2008, 11:05 PM
  3. vw golf making loud noise when turning and also when travelling on uneven roads
    By madz in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-05-2007, 06:40 PM
  4. Uneven Tickover
    By Tvr in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-10-2006, 11:16 PM
  5. 2000 Polo E uneven tickover
    By Bobbie83 in forum Polo - Derby - Lupo - Fox
    Last Post: 31-01-2006, 11:21 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
VW Audi Forum is an AUTHORISED retailer for the Surf City Garage range of car care products
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
