Thread: VW Polo heater not working ???
Results 1 to 10 of 11
  1. VW Polo heater not working ???
    Feb 2007
    I have a friends W plate Polo 1.0 outside now and im trying to work out why the heater is only blowing cold air. All pipes are hot,ive run the engine with the cap off the tank and there are no air locks !
    Any ideas ??
    Nov 2006
    water pump impellor falls of the water pump so it doesnt circulate coolant properley.
    Feb 2007
    Quote Originally Posted by paulb View Post
    Eventhough the car is running at normal temp and all pipes are hot etc ??
    Does this still sound like a failed water pump ?
    Feb 2007
    glasgow
    I've done one of these were the impellor had fallen off but was still runnig ok no overheating just no hot air its worth a look. M
    Feb 2007
    Quote Originally Posted by marty72 View Post
    Sounds like it needs replacing then. The car only has 32,000 miles on it !! I will replace the cambelt aswell,should anything else be changed at the same time ?
    Feb 2007
    glasgow
    Hi its a good idea to do the adjuster and guide rollers if your doing the belt.M
    Feb 2007
    Ok,will do all that at the same time. Out of interest,how much would this job cost for the main dealer to do ?
    Nov 2006
    i work at a vw retailer this is a common problem with polo water pumps,also sometimes the thermostat comes through the plastic housing aswell inside,this is worth a look aswell,if going to replace cambelt make sure you replace cambelt tensioner as sometimes they dont tension up properley.
    Aug 2006
    Devon, UK
    I'd guess at around £300 all in.
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
  10. Re: VW Polo heater not working ???
    Dec 2007
    Same problem on my N plate 1.4 Will give it a try as the (shivering) Missus has thrown a wobbler this morning
  1. Polo Heater cold at tick over
    By GrahamS in forum VCDS - General Questions
    Last Post: 25-08-2011, 08:21 PM
  2. Polo heater problem
    By bulkokid in forum Polo - Derby - Lupo - Fox
    Last Post: 25-08-2011, 08:10 PM
  3. 96 passat heater fan not working
    By macerena in forum Passat - Archive Topics
    Last Post: 08-03-2007, 07:49 PM
  4. Heater working on passager side only
    By redlancer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-11-2006, 09:51 AM
  5. Club Polo & Performance Polo sho
    By stuart in forum Shows & Events
    Last Post: 18-07-2004, 03:47 PM
