Thread: Power steering problem - Loose Belt?
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: Power steering problem - Loose Belt?
    Sep 2008
    Birmingham
    Good work!
  2. Re: Power steering problem - Loose Belt?
    May 2008
    E-mail me for the additionall pics as I can't upload them as there too big!
  3. Re: Power steering problem - Loose Belt?
    May 2008
    thanks
  4. Re: Power steering problem - Loose Belt?
    Have had a look at mine, and firstly found it difficult to remove the plastics.
    This I think has prevented me from getting as much access as I want, but I feel I should still be able to tighten it, as the belt is less than a year old, and there is still sufficient travel.
    Found the adjustment bolt easy enough, but where are the bolts securing the power steering pump, presuming this is the lowest part of the system, and is closest to the adjustment bolt.
    Thanks in advance
  5. Re: Power steering problem - Loose Belt?
    May 2008
    Quote Originally Posted by baby-mechanic View Post
    Thanks in advance
    I have pm'd you some pics as it will not let me attach them.
  6. Re: Power steering problem - Loose Belt?
    Hi WadeNeil
    Thanks for getting back to me
    As yet they've not come through, if you're able to try my msn address, using my handle here, followed by the dot com version
  7. Re: Power steering problem - Loose Belt?
    #17
    trying to get
  8. Re: Power steering problem - Loose Belt?
    #18
    the five posts
  9. Re: Power steering problem - Loose Belt?
    #19
    i need to send a pm !
  10. Re: Power steering problem - Loose Belt?
    #20
    Feb 2009
    Quote Originally Posted by WadeNeil View Post
    Sorry for late reply - only got round to changing the belt yesterday.
    Yes the red circled bolt is the adjustment and I had to change the Power Steering belt as the adjustment was at its full travel(as shown in earlier picture)
    A quick How to....(well how I did it)
    Firstly removed the wheel (I found it easier to work on) and jacked up. And removed some of the plastics.
    Then slackened of the 3 bolts that hold the power steering pump
    (1 hinge bolt and 2 Slide bolts) as shown in the pics.
    Slackened off the old belt and removed (it was allot bigger than the new one!!!) Gentle tapping with hammer on the power steering pump with the adjustment bolt removed was needed.
    Put new belt on, adjusted and the re-tightened the 3 bots.
    And no more squealing!!! Total cost = £3.19
    I will add more pics underneath as it won't le me add any more to this reply.
    anyone know where i can get a new adjustment bolt for my mk3 tdi as the teeth are worn?
  1. power steering belt replacement
    By issyfit in forum The Commercial Range
    Last Post: 04-01-2009, 01:41 PM
  2. Power steering pump / belt problem tdi
    By Kingfisher1 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-08-2008, 04:59 PM
  3. Sharan power steering belt
    By renamecor in forum Touran - Sharan - Caravelle
    Last Post: 16-05-2008, 12:37 AM
  4. Power steering belt
    By loucla93 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-11-2007, 12:56 PM
  5. power steering belt adjustment
    By alan lee in forum Archive posts
    Last Post: 20-03-2007, 09:36 PM
