Thread: P0234 Engine overboost Condition
Results 1 to 10 of 12
  1. P0234 Engine overboost Condition
    Sep 2008
    Liverpool
    0
    Hi Guys, Just bought a Mk5 140 tdi, no lights on when i got it and it drives around town superb loads of boost from the turbo and will rev all the way up.
    I get it on the motorway and try to accelerate next thing you know about 60-75 mph the car goes into limp mode. I have plugged in a cheap code reader and I am getting the P0234 Engine Overboost Condition code.
    I have done a ton of reading on here and the other gti forum regarding cleaning the Inlet Guide vanes in the turbo.
    I am just after a bit of advice regarding this, before I go whipping my turbo off and giving it a clean.
    is there any other faults that could cause these symptoms, ie put the turbo into an overboost position other than sticky IGV's?
    Thanks Dave.
  2. Re: P0234 Engine overboost Condition
    197
    If the turbo is wheezing and whining, it usually needs replacing, this is a massive problem on the BKD engine. There is s spray cleaning system available from Inotec that allows the vanes to be cleaned without removing the turbo, if this fails it is new turbo time.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
    www.helpforheroes.org.uk
    Keep XH558 in the air
    www.vulcantothesky.org
  3. Re: P0234 Engine overboost Condition
    Sep 2008
    Liverpool
    0
    Cheers for the quick reply crasher, I will have a look into that spray cleaning solution now.
    BTW is this the only cause of the Engine overboost condition? or could it be a dodgy sensor?
  4. Re: P0234 Engine overboost Condition
    Sep 2008
    Liverpool
    0
    Just tried googling Inotec, to try and find a lead on this cleaning solution but to no avail, anything else that could point me in the right direction please crasher? Cheers for your time.
  5. Re: P0234 Engine overboost Condition
    197
    I can supply by mail order but not sure of the price until Monday when I can look on the works system.
  6. Re: P0234 Engine overboost Condition
    Sep 2008
    Liverpool
    0
    Crasher , Cheers. I will PM you my mobile, give me a text or leave a message on my phone( phones not allowed in work) and I will call you back during business hours and get it ordered. Thanks for your help.
  7. Re: P0234 Engine overboost Condition
    Sep 2008
    Liverpool
    0
    Update: Got the car up on ramps today and did a visual inspection of hoses , all seemed fine, worked the vanes by hand and didn't notice any sticking or noises, so took off the pipe with the MAP sensor fitted to it and what looks like oil started dripping out, cleaned the pipe, run a coule of kettles of boiling water over the map sensor refitted it and put the lot back together, took it for a very hard driving session on the motorway, and now can not get it to fail into limp mode now. Happy with the result, not so happy with oil being in the pipe between the cooler and inlet manifold and covering the MAP sensor. checked oil when I got home and it is about a litre overfull, going to drain a bit tomorrow, but now need to find out if this is the reason for the pipes having oil in or is this normal?
    Checked service history and oil was changed at VW dealers 700 miles ago.
  8. Re: P0234 Engine overboost Condition
    197
    Oil in the pipes is completely normal and nothing to worry about. Some comes out of the turbo and some from the crankcase breather.
  9. Re: P0234 Engine overboost Condition
    Sep 2008
    Liverpool
    0
    Cheers Crasher, thats put my mind at ease.
  10. Re: P0234 Engine overboost Condition
    Sep 2008
    0
    There is a fault with some of the 2.0 TDi's where the wiring from the boost sensor to the ECU has high resistance. To fix this we fit an adapter loom and clean all earth points along the N/S. Check the earth points to see if corroded.
  1. Question Belt for Air Condition Unit?
    By karachi_kops in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-08-2008, 08:34 PM
  2. air condition
    By suomis in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-07-2008, 08:44 AM
  3. battery condition
    By waggy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-05-2008, 08:42 PM
  4. P0234-turbo Overboast
    By jp4500 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-04-2008, 06:18 PM
  5. Over Boost Code p0234
    By whiteturbo in forum Archive posts
    Last Post: 24-01-2008, 04:13 AM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
