Thread: Does anyone have experience of the ESP warning light on the dash?
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: Does anyone have experience of the ESP warning light on the dash?
    #21
    106 Post(s)
    1813 Post(s)
    It would be code 01435 but there are four divisions to this code, 005 no or incorrect setting/adaptation, 088 Implausible signal, 012 fault in electrical circuit and 00 sporadic.
    Whatever conclusion you come to, G201 is inside the pump so that must be replaced or repaired, you can chase around until the cows come home and it will not change this fact.
  2. Re: Does anyone have experience of the ESP warning light on the dash?
    #22
    Aug 2008
    Thanks for the clarification Crasher. It's just that this (£1,500) is a very hard pill to swallow!!
    I have also been using a Touran forum and it seems there are many others who have suffered this ESP/ABS pump problem over the last 12 months.
    Apparently it is becoming quite an issue on Tourans and some Golf models.
  3. Re: Does anyone have experience of the ESP warning light on the dash?
    #23
    106 Post(s)
    1813 Post(s)
    The same pump is used on Golf 5, Golf Plus and Caddy as well as the Touran and is becoming a common issue.
  4. Re: Does anyone have experience of the ESP warning light on the dash?
    #24
    Oct 2009
    Also an issue for Audi A3. My 06 plate car has developed the fault.
  5. Re: Does anyone have experience of the ESP warning light on the dash?
    #25
    106 Post(s)
    1813 Post(s)
    I forgot to mention the 8P series A3 as well as the Octavia 2, Leon 2, Altea and Toledo 3.
  6. Re: Does anyone have experience of the ESP warning light on the dash?
    #26
    Aug 2008
    Sorry to hear about yur problem Peter. However from the Touran forum it now seems that VW are recognising as a fault and are making significant contributions to the repair, unlike the early days when they denied there was a problem and offered nothing to tose out of warranty.
    It seesm the problem is now too big to ignore. You should push VW hard for compensation.
  7. Re: Does anyone have experience of the ESP warning light on the dash?
    #27
    derby
    hi there
    The touran seems to have this problem alot if you get it scanned it will come up with the brake load sensor electrical fault in circuit this sensor is in the ABS pump thats why it cost so much. Hope this helps a little
  8. Re: Does anyone have experience of the ESP warning light on the dash?
    #28
    Mar 2007
    Fareham, Hants
    This is all very interesting! We have had the light on in our car for a while (04 TDi sport), just cant afford to get it looked at and these posts aren't helping matters.
    The ABS seems to be working when doing brake tests, but the downside is its chewed through the front tyres in no time at all
    The car does seem a money pit lately, 2 CV boots and the EGR flap at £700+, now potentially this £1500 ESP deal....
    How can I go about getting the Vag.com test done near Fareham, Hants. Dont really want to go VW as the quotes are very high just to plug in the diagnostics!
    TIA
    Tim
    ps blimey reg'd 2007 and this is my 1st post LOL.
  9. Re: Does anyone have experience of the ESP warning light on the dash?
    #29
    106 Post(s)
    1813 Post(s)
    The ESP not functioning has no effect on the ABS and will not affect tyre wear unless you are driving the car in a completely on the edge manner, ESP is a last chance catch fence before you end up in a ditch, it may be a coincidence but having new CV boots fitted can adversely effect the alignment, I suggest the front wheel alignment is checked before you scrub out two new tyres. Almost any garage can do a fault code read and expect to pay around £30.
  10. Re: Does anyone have experience of the ESP warning light on the dash?
    #30
    Mar 2007
    Fareham, Hants
    No! We dont drive like loons but if you accellerate too hard it wheel spins in 1st-3rd sooo easily.
    Appreciate your advice thankyou
  1. Warning light on dash orange with key on it
    By johno in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-07-2010, 11:24 AM
  2. Dash warning light
    By Lagerman in forum Beetle 2000-
    Last Post: 24-05-2008, 06:23 AM
  3. dash warning light T4
    By andrew pearce in forum The Commercial Range
    Last Post: 24-03-2008, 09:38 PM
  4. Stop Warning Light In Dash
    By Passatguy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2007, 09:23 AM
  5. Dash Warning Light
    By lordcakes in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-06-2007, 08:13 PM
