Thread: Bora ABS Fault and Brake Fault
  1. Talking Bora ABS Fault and Brake Fault
    Jul 2007
    Ashbourne
    Hi folks,
    Just had the DMF and clutch replaced on my 2000 1.9TDI Bora 90hp.
    The guy who fitted the parts advised me that my front discs and pads were worn and would need replacing for mot.
    A few days after I had the ABS light illuminate and the red display said 'ABS Fault'
    I carried on driving as everything seemed fine. The ABS light stays on continously now.
    The other day I got a brake fault along with the ABS fault.
    SO now I have 2 faults and the display reads 'Brake Fault' 'stop' and beeps at me.
    So far I have still been using the car as the brakes are fine.
    Ive topped up the brake fluid level and the fault is still there.
    What do you guys think? should I put new pads on and a new abs sensor(s) and see if it goes away or get the fault code read?
    If I need the code reading will it be cheaper to buy the leads and get the software and read it myself rather than having VW or similar specialist read it?
    I have searched thru the forum under 'ABS fault' and looked at all the posts so I hope you dont think I am posting for the fun of it.
    Any advice much appreciated - cheers.
    PS brakes feel fine am I ok still driving it with the 2 fault mentioned above?
    There is still meat left on the pads.
  2. Re: Bora ABS Fault and Brake Fault
    Quote Originally Posted by jonty89 View Post
    Hi folks,
    Have a quick check to make sure the cable that links to the sensor is OK, it may be loose or damaged......
    POLO 6R 1.2 TDI MATCH (2012) lets see if this will do over 200K
    Bora SE PD130 (2003) 200k & still going
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. ABS/Brake Fault
    By colhowe1 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-04-2008, 05:33 PM
  3. bora ABS fault
    By EVILUTION in forum Bora - 1998 - 2005
    Last Post: 05-12-2007, 06:36 AM
  4. Some questions about Brake Fault and fluid?
    By DevilGateRider in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-11-2007, 01:44 PM
  5. First Brake Fault
    By Big G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-11-2007, 09:14 AM
