Thread: power steering belt replacement
  1. power steering belt replacement
    Jul 2008
    hi all first post on this site i have a 1996 vw transporter 800 special 1.9 td would like some info on changing the power steering belt.
  2. Re: power steering belt replacement
    spain
    Quote Originally Posted by issyfit View Post
    hi there changed the belt on my t4 very simple job,
    just undo two bolts on alternator ,move inwards lift of belt from power steering pulley and alternator pulley, put new belt on and retension belt job done.
    ps if you have aircon you will have to remove that belt as well.
    my engine is 2.4d but guess its the same.
    The weather today will be hot and sunny. At casa naranja guest house this is true on average 320 days a year!!!
  3. Re: power steering belt replacement
    mike-snapper Guest
    Thats not helped. pas belt not the alternator. alternator is simple, pas is in the way though.
  4. Re: power steering belt replacement
    spain
    Quote Originally Posted by mike-snapper View Post
    sorry cant be any more help as on my engine the power steering and alternator belt is the same one
  5. Re: power steering belt replacement
    mike-snapper Guest
    Found it, Split the pulley, three bolts undo there are i found brass spacers inside, some of which I removed to ensure a tight belt when they were done up.
    it worked, belt home, no squeaking even under load. hope it helps.
    Mike
  6. Re: power steering belt replacement
    Jan 2009
    Mike
    Brilliant! Just what I was hoping to find! No more sqealing for me!
    Thanks!
    Farl
  1. Power steering belt vibrating and slipping
    By Morfa18 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2008, 08:13 PM
  2. Sharan power steering belt
    By renamecor in forum Touran - Sharan - Caravelle
    Last Post: 16-05-2008, 12:37 AM
  3. Power steering belt
    By loucla93 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-11-2007, 12:56 PM
  4. 80 1.8 estate power steering belt change
    By Inspectorgadget in forum 80 - 90
    Last Post: 01-08-2007, 08:51 PM
  5. power steering belt adjustment
    By alan lee in forum Archive posts
    Last Post: 20-03-2007, 09:36 PM
