Thread: VW Golf gt tdi 115 ASR light & ABS light
  1. Angry VW Golf gt tdi 115 ASR light & ABS light
    MANCHESTER
    Hi Guys, can any one help?
    I have a golf gt tdi 115 2000 i disconnected the battery to put a new bulb in and when i reconnected the battery and switched the engin on my ASR warning light and ABS light have come on and will not go of now. Any ideas what the problem could be.
    I have allready disconnected the battery for half hour or so but no luck.
    I had the same problem. What I found was the fuse unit that sits on the battery has a connector that partially unplugged. This must have happened when I pried it out of the way to replace the battery. It caused the ABS and brake fluid level warning lights to turn on. Resnugging the connector caused the lights to go off.
    Newcastle
    This has just happened to me while changing the air filter...
    There is a small connector that plugs in to the main tube connected to the air filter and i removed it to take the filter lid off and forgot to re-connect it. When restarting the car and the abs light was on, but when i connected it back up it stayed on and thought i would have to get the fault removed from the ECU. But i turned the engine off re-connected the cables and went shopping (i feel this is the key to it working) when i came back and started the car the light was off.. (car was off for an hour)
    Maybee you have nocked this connector while removing the battery lid or the fuse unit that sits on the battery has a connector that partially unplugged as said by Bernie Gorski.
    I don't know if this is any help but i can try
    SanderCH...
    Broken Bones Will Heal, But Pride Is Forever
    this thread may be of some use to you, i know the OP is stating a traction control and ABS light, but could be a similar fault?
    https://www.vwaudiforum.co.uk/forum//...ead.php?t=1887
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    I had a wiring issue where one of my ABS sensors wasn't working right, and it kills the whole ABS / ASR system. The ECU should tell you where the problem lies. It can be a bit annoying to have 2 key safety systems taken down by one sensor, but with all the traction/ABS being related, I guess there's no choice in the matter.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
  1. Replies: 10
    Last Post: 28-06-2010, 09:12 PM
  2. Brake Light / Tail Light Changing Avant
    By Gazz in forum Audi A4 - Archive Topics
    Last Post: 20-11-2007, 10:23 AM
  3. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
  4. Only the high level brake light and flahing coil light
    By 49forever in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-05-2007, 04:41 PM
  5. Mk3 TD: Oil light blinks, rev counter at zero, dim battery light
    By num_tubes in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-11-2006, 01:28 PM
