Thread: Filter change on 2.5TDi
  1. Question Filter change on 2.5TDi
    Aug 2006
    Before I take off all the plastic protective engine covers, can anybody tell me how easy it is to change the oil, air and fuel filters on the Audi 2.5 TDi (1999) engine?
    london/ UK
    Quote Originally Posted by wanstronian View Post
    Verry easy, the oil filter is loccated on the right hand side(passenger) and you will need a big socket(32mm i think) to undo the black plastic housing, also the front under shield needs to be remmoved to gain acces to the sump's plug. Its good to warm the engine prior changing the oil as it will drain quicker ! Be carrefull not to scald yourself when draining the oil. Use common sense ! Please note the way the filter goes as its important ! Replace the O ring seal supplied in the kit(genuine/OEM quallity filters from dealer, Euro car parts, GSF, etc.) Air filter is in the big black box on the left hand side(driver side) and you need to unclip and replace the filter. Fuel(diesel filter) is loccated on the driver side and make shure you fill it with clean diesel to minimise the strain on the battery, also note the way the pipes go ! Thats it. Take your time and have a beer when you done !
  1. DSG Oil and filter change
    By Jonnybegood in forum Audi A3 - Archive Topics
    Last Post: 30-05-2007, 03:30 PM
  2. Air filter change
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-04-2007, 11:58 PM
  3. Oil & Filter Change
    By s0niX in forum Polo - Derby - Lupo - Fox
    Last Post: 20-04-2007, 06:26 PM
  4. How do i change the oil filter 2004 Golf 2.0 TDI
    By daveaustin in forum Archive posts
    Last Post: 17-04-2007, 11:34 PM
  5. Air Filter Change Advice?
    By Topbidder in forum Passat - Archive Topics
    Last Post: 12-10-2006, 12:24 PM
