Thread: 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
Results 1 to 10 of 16
  1. 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    Jun 2008
    I've got a 1.9TDI VW Golf and have a problem,
    todays ago i was on tht motor doing 85 and out of the blue i lost power and now i cant get over the 70 mark. if i run the car off and start is back up a min later everything works fine until i hit the 70 mark again.
    please can someone tell me what i need to do to fix this problem,
  2. Re: 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    Jun 2008
    The Wee County
    http://wiki.ross-tech.com/index.php/17965/P1557/005463
    Above link is a good starting point.
  3. Re: 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    Jun 2008
    Thank you for that information, where do i find the Solenoid Valve for Boost Pressure Control (N75) defective? as i dont know what it looks like,
    has anyone else had this problem?
  4. Re: 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    Dec 2007
    Suffolk
    Im pretty sure thats the code it throws when the vanes are stuck in the turbo (VNT).
  5. Re: 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    Jun 2008
    The Wee County
    Location of the solenoid valve and associated hoses etc.
    Some slight differences with various engine codes but the basic locations are the same in most cases.
    Attachment removed due to copyright issues... Elsa is licenced to VAG dealers only
    as far as we are aware.
    Please confirm that you own the official copyright to this material
    before posting! As per the Forum Rules.
  6. Re: 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    1840 Post(s)
    17965, 99% of the time is jammed vanes.Try finding someone who keeps the Innotec decoke kit in stock.
  7. Re: 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    Jun 2008
    Hi, thank you for your help,
    i spoke to VW - TPS in Coventry and i got told that its a problem with the N75 or the Turbocharger (TC) Wastegate Regulating Valve,
    ive just order the replacement parts from the main dealer. ill let everyone know what happens,
  8. Re: 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    1840 Post(s)
    The TDI N75 rarely fails but it does happen and the TDI doesn’t have a recirculation valve, that is used on the petrol engine. What is the engine code or horsepower?
  9. Re: 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    Oct 2005
    Quote Originally Posted by smithysmudger View Post
    Could I ask where you got the docs from?
  10. Re: 17965 Tubro Pressure Control Limit Exceeded - P1557 Error on my car
    Feb 2004
    Yorkshire
    46 Post(s)
    Attachment removed as per Forum rules regarding copyrighted material.
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Member of BMW Car Club GB
    Ways to support the website
  1. Error Code 17965
    By Sharky_82 in forum VCDS - General Questions
    Last Post: 29-07-2011, 12:22 PM
  2. Control limit exceeded cylinder 4 injector pump
    By jimgironde in forum VCDS - General Questions
    Last Post: 03-10-2008, 05:57 PM
  3. 17958 - Charge Pressure: Control Deviation
    By andy1max in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2008, 08:39 PM
  4. error code 17965 on 110 tdi, need a new actuator?
    By tezray in forum Archive posts
    Last Post: 26-10-2007, 04:56 PM
