Thread: 2001 Passat Licence Plate Light Issues
  1. 2001 Passat Licence Plate Light Issues
    Nottingham
    Hi there,
    I've got a 2001 Passat TDI (PD engines) saloon. I've reciently been fingered on the Licence Plate lights not working on the car which was a "doh!" moment.
    - I changed the bulbs since they looked a bit black, but are all ok.
    - checked the fuse (number 4 in the panel), and that seems ok. Checked all other fuses for the hell of it, but they seem ok too.
    - checked all lights on the car (with my mother checking while I try them, which prob not the best idea in itself...lol), they seem ok too.
    I'm a bit at a loss to where to go from here. Anyone got any ideas?
    Max
  2. registration lights
    scotland
    39 Post(s)
    Hi Max,
    I had this problem prior to mot time,if you take out the bulbs and use wd 40 with a wire brush or even an old toothbrush to clean the contacts.If this doesn't help, use something a little more abrasive like some wet n dry emery paper if this results in success give the contacts a light coating of vaseline this will stop any further corrosion .Vaseline can also be used on battery terminals and also the brake pad pins,invaluable stuff,well good luck and hope this helps out , Calum
    as above, vaseline and WD40, millions of uses, some legal.....others not so quite LOL
    Nottingham
    thanks both, works a treat, i can rest my head as VW go charge me a fortune for servicing it on monday lol!
    Last edited by Max-Power; 06-01-2007 at 11:29 AM. Reason: included "not" when i shouldn't have lol
  1. Engine Warning Light 2001 Passat
    By derekdublin in forum Passat - Archive Topics
    Last Post: 09-02-2007, 08:10 PM
  2. Passat 2001 1.8T - ABS Warning Light On!
    By richard child in forum Passat - Archive Topics
    Last Post: 19-01-2007, 08:40 PM
  3. Passat 2001 1.8T - ABS Warning Light On!
    Last Post: 17-01-2007, 05:38 PM
  4. GOLF V5 'Dead As A Dodo' 2001 Plate
    By Bluebell in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-12-2006, 04:39 PM
  5. Warning Light 51 plate Passat
    By 3BG in forum Passat - Archive Topics
    Last Post: 06-12-2006, 08:54 PM
